The tiling scheme of a WMTS layer is incompatible with the tiling scheme of the surface
659
07-27-2025 03:04 PM
AliMahdian
I want to add a WMTS layer to a SceneView, but I encounter the following error when adding the layer to the map. Can anyone assist me?
"The tiling scheme of this layer is incompatible with the tiling scheme of the surface"
const wmtsLayer = new WMTSLayer({
        url: "http://localhost:8080/geoserver/gwc/service/wmts",
        activeLayer: {
            tileMatrixSetId: "EPSG:900913"
        spatialReference: {
            wkid: 102100
        customLayerParameters: {
            VERSION: '1.1.1',
            FORMAT: 'image/png',
            TRANSPARENT: true,
            // SRS: 'EPSG:3857'
    const osmLayer = new WebTileLayer({
            urlTemplate: "https://tile.openstreetmap.org/{z}/{x}/{y}.png"
    osmLayer.load().then(function() {
        console.log("OSM Tile Info (example for Web Mercator comparison):", osmLayer.tileInfo.toJSON());
    map.add(osmLayer);
    map.add(wmtsLayer);
Noah-Sager
Hi @AliMahdian, do you need to use the same spatial reference? It looks like you use 2:
 and
wkid: 102100
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-support-WMTSSublayer.html#...
