the  tree node  can't  click in the extJS freamwork  with  arcgis  for js
1488
10-16-2012 09:23 AM
yanli
when  i  put a  extjs  tree  in the example
http://help.arcgis.com/en/webapi/javascript/arcgis/samples/framework_extjslayout/index.html
,i  click  the node  ,but  can't  work ,  what's wrong  ? can  u help?
[HTML]
<!DOCTYPE HTML>
  <head>
    <title>
      ExtJS Layout Example
    </title>
    <link rel="stylesheet" type="text/css" href="http://cdn.sencha.io/ext-4.0.7-gpl/resources/css/ext-all.css"/>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css" />
    <style type="text/css">
      html, body {
        font:normal 12px verdana;
        margin:0;
        padding:0;
        border:0 none;
        overflow:hidden;
        height:100%;
    </style>
    <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2compact"
    type="text/javascript"></script>
    <script type="text/javascript" charset="utf-8" src="http://cdn.sencha.io/ext-4.0.7-gpl/ext-all.js"></script>
    </script>
    <script type="text/javascript">
      dojo.require("esri.map");
      dojo.require("esri.layers.FeatureLayer");
      dojo.require("esri.dijit.Popup");
      dojo.require("dojo.number");
      var map;
                          //****************the tree  that  i  add
            var yewuTree=new Ext.tree.TreePanel({
          root:{
      text:"1",
      expanded:true,
      children:[
        text:"2",
     expanded:true,
     children:[
     text:"3",
     leaf:true
     text:"4",
     leaf:true
         text:"5",
      leaf:true,
      listeners:function(node)
        alert("aaa");
     yewuTree.on("click", function(node) {
       alert("aaaa");
  // yewuTree.getSelectionModel().getSelectedNode();
      function init() {
        var viewport = new Ext.Viewport({
          layout: "fit",
          title: "EXT JS Layout",
          items: [{
            layout: "border",
            items: [{
              region: "center",
              title: "center",
              html: "<div id='map' style='height:100%; width:100%;z-index=: 1000;'></div>"
              region: "north",
              height: 50,
              collapsible: false,
              contentEl:"header"
              region: "south",
              height: 80,
              collapsible: false,
              contentEl: "footer" // this gets the content from the div named "footer"
              region: "west",
              title: "Left Panel",
              width: 150,
              split: true,
              collapsible: true,
     layout:'fit',
     items:yewuTree,
            //  html: "Left panel content. This panel is collapsible and can be resized using the splitter",
              listeners:{
                collapse: resizeMap,
                expand: resizeMap
              region: "east",
              width: 200,
              xtype: 'tabpanel',
              activeTab: 0, // index or id
              items:[{
                  title: 'Tab 1',
                  html: 'This is tab 1 content.'
                  title: 'Tab 2',
                  html: 'This is tab 2 content.'
                  title: 'Tab 3',
                  html: 'This is tab 3 content.'
       var initialExtent = new esri.geometry.Extent({"xmin":-118.61,"ymin":34.34,"xmax":-118.09,"ymax":34.56,"spatialReference":{"wkid":4326}});
        var popup = new esri.dijit.Popup(null, dojo.create("div"));
        map = new esri.Map("map", {
          extent: esri.geometry.geographicToWebMercator(initialExtent),
          infoWindow: popup
        dojo.connect(map, 'onLoad', function(theMap) {
          dojo.connect(window, 'resize', map, map.resize);
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(basemap);
        var template = new esri.dijit.PopupTemplate({
          title: "Geologic Outcrop",
          description:"{lithology_type} with the following metamorphic facies: {metamorphic_facies}"
        var featureLayer = new esri.layers.FeatureLayer("http://sampleserver5.arcgisonline.com/ArcGIS/rest/services/Energy/Geology/MapServer/9",{
          mode:esri.layers.FeatureLayer.MODE_SNAPSHOT,
          infoTemplate:template,
          outFields:["lithology_type","metamorphic_facies"]
        map.addLayer(featureLayer);
      function resizeMap() {
        map.resize();
      dojo.addOnLoad(init);
    </script>
  </head>
  <body>
    <!-- use class="x-hide-display" to prevent a brief flicker of the content
    <div id="header">
       <span>Header content goes here</span>
    </div>
    <div id="center" class="x-hide-display" style="z-index: 100;">
    </div>
    <div id="props-panel" class="x-hide-display">
    </div>
    <div id="footer" class="x-hide-display">
      <span>Footer content goes here<span>
    </div>
    <div id="north" class="x-hide-display">
    </div>
  </body>
</html>
[/HTML]
