I try to add obr format file as attachment. OBR files are text files containing the unique ID of the document in an Objective electronic document/records management system. The size is only 9 bytes. It is OK to add file by ArcMap, but when I add through feature service by Javascript, I have the error message "File Type not supported". Is there any way to configure the settings to support new file type?
I have the same problem with mail files (.eml).
Did you find any solution?
