Test a Shapefiles Geometry
2254
12-15-2014 11:27 AM
jaykapalczynski
Honored Contributor
I have an app that is allowing the user to add a shapefile to the map.  I need to test for its geometry before or after adding.
var allShapeFileLayers = [];
                function addShapefileToMap (featureCollection) {
                                var fullExtent;
                                var layers = [];
                                   arrayUtils.forEach(allShapeFileLayers, function(layer) {
                                                 app.map.removeLayer(layer);
                                arrayUtils.forEach(featureCollection.layers, function (layer) {
                                                var infoTemplateSF = new InfoTemplate("Details", "${*}");
                                                var featureLayerSF = new FeatureLayer(layer, {
        infoTemplate: infoTemplateSF
                                                 featureLayerSF.on('click', function (event) {
                                                app.map.infoWindow.setFeatures([event.graphic]);
                                  changeRenderer(featureLayerSF);
                                  fullExtent = fullExtent ?
                                                fullExtent.union(featureLayerSF.fullExtent) : featureLayerSF.fullExtent;
                                  layers.push(featureLayerSF);
                                allShapeFileLayers = layers;
                                app.map.addLayers(allShapeFileLayers);
                                app.map.setExtent(fullExtent.expand(1.25), true);
                                dom.byId('upload-status').innerHTML = "";
                               dojo.byId("RunQueryShapefile").style.display = "block";
           // TEST FOR POLYGON ONLY
          if ( allShapeFileLayers.geometry.type === "point" || allShapeFileLayers.geometry.type === "multipoint") {
              alert("Point or multiPoint");
          } else if ( allShapeFileLayers.geometry.type === "line" || allShapeFileLayers.geometry.type === "polyline") {
              alert("Poline or polyline");
          else {
              alert("Polygon");
jaykapalczynski
Honored Contributor
GOT IT WITH THIS....just moved the If Else inside the arrayUtils.ForEAch to test....
                                var fullExtent;
                                var layers = [];
                                var GeometryTypeShapefile = featureLayerSF.geometryType;
                                //alert(GeometryTypeShapefile);
                                if (featureLayerSF.geometryType === "esriGeometryPoint" || featureLayerSF.geometryType === "esriGeometryMultipoint") {
                                  } else if (featureLayerSF.geometryType === "esriGeometryLine" || featureLayerSF.geometryType === "esriGeometryPolyline") {
                                                alert("line or polyline");
                                 } else if (featureLayerSF.geometryType === "esriGeometryPolygon") {
                                                 alert("Polygon");
                                } else {
                                                 alert("No Geometry");
jaykapalczynski
Honored Contributor
Wondering if I should bring the shapefile in and then write its features to a GraphicLayer?
Write them to a FeatureLayer?
Then test for Geometry?  Thoughts?
jaykapalczynski
Honored Contributor
                                var fullExtent;
                                var layers = [];
                                                 alert("Polygon");
                                } else {
