Syntactical question regarding QueryTask where clause
1478
11-05-2019 07:19 AM
FranklinAlexander
I am using QueryTask to query an ArcGIS REST service feature class. The field I need to query is a esriFieldTypeInteger, and I am having trouble getting syntax correct in the where clause. I need to query features using a list or array of IDs and I haven't been able to find enough documentation to get the proper syntax. I am taking a string of IDs from a document input element and trying to use that list to query the features. I assume that I need to convert them to integers since the field values are integers, but am I wrong? Here is what I have tried, but the query is not executing so the problem must be with the where clause.
  _getAndDisplayResults: function() {
        let ifrm = window.frameElement;
        console.log("iframe element ", ifrm);
        let document = ifrm.ownerDocument;
        console.log("document ", document);
        let ids = document.getElementById("phga_ids_results").value;
        console.log("phga results from text box",ids);
        let numids = ids.split(',').map(Number);
        console.log("phga converted results ",numids); //this returns an array of integers
        let url = "https://ocean.floridamarine.org/arcgis/rest/services/.../MapServer/0";
        let queryTask = new QueryTask(url);
        let wmaQuery = new Query();
        wmaQuery.where = "PHGA_ID IN " + numids;
        console.log("where clause ", wmaQuery.where);
        wmaQuery.outFields = ["*"];
        wmaQuery.returnGeometry = true;
        queryTask.execute(wmaQuery).then(function(result) {
            console.log("wma results ", result); //get nothing here. Not executing
            //let wmaArray = [];
            //let features = result.features;
            //features.forEach(function(feature) {
                //var geometry = feature.geometry;
                //wmaArray.push(feature);
Any ideas as to what I have wrong with the syntax?
FranklinAlexander
Got it to work. Just missing the "()". Here is the working whereclause:
wmaQuery.where = "PHGA_ID in (" + numids + ")";
FranklinAlexander
