Symbol remains clustered when zooming in with Feature Reduction enabled
1908
08-06-2021 06:24 AM
FranklinAlexander
I am have Feature Reduction enabled on a layer and at some point when zooming in to a cluster it should break apart into single graphics. This does not happen for some clusters no matter how much I zoom in.
I tried changing the cluster radius, going as small as 20, but I get the same result. This appears to be happening for any cluster when the features are less than 1000 meters apart:
Here is the cluster as it appears in the app:
 Here are the actual features as they should appear:
I need the single graphics to appear in the app because user need to be able to click the feature to get more info. Please let me know if there is a fix.
rogenjh
You watch the scale and remove the feature reduction cluster at a certain scale.
You can see this happening on this example: Sample .
Key code:
        layer
          .when()
          .then(generateClusterConfig)
          .then(async (featureReduction) => {
            // sets generated cluster configuration on the layer
            layer.featureReduction = featureReduction;
            // the layer view is needed for querying clusters
            layerView = await view.whenLayerView(layer);
            // Disable clustering when user zooms beyond a 1:50,000 scale level
            // Re-enable clustering when the user zooms out to a scale smaller than 1:50,000
            view.watch("scale", (scale) => {
                view.scale > 50000 ? featureReduction : null;
          .catch((error) => {
            console.error(error);
rogenjh
Key code:
        layer
          .when()
          .catch((error) => {
FranklinAlexander
Thank you for that suggestion. I am using the 3x API, so I had to adapt the code accordingly but it's working.
