Symbol could not display when turn on base map
1345
08-26-2013 11:07 AM
LouPhan
I create a layer and upload to my arcgisserver, it displays well. I can see and click the symbol when i make a query.
However, when i add the base map, the symbols of query's results could not display or click.
map = new esri.Map("mapDiv", {
          basemap: "hybrid",// have a base map. Remove this code to delete the base map.
          center: [-34.541, 32.843],
          zoom: 3
When i try to use a layer from:
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...
Everything works fine.
I really don't know how to fix it. Here is information of my layer.
Drawing Info:
Renderer:
Simple Renderer:
Symbol:
Simple Fill Symbol:
Style: esriSFSSolid, Color: [Undefined]
Outline:
Simple Line Symbol:
Style: esriSLSSolid, Color: [255, 255, 255, 255], Width: 1
Here is information of the sample:
Drawing Info:
Renderer:
Simple Renderer:
Symbol:
Simple Fill Symbol:
Style: esriSFSSolid, Color: [206, 205, 250, 255]
Outline:
Simple Line Symbol:
Style: esriSLSSolid, Color: [110, 110, 110, 255], Width: 0.4
Here is my HTML code:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <title>QueryTask with value, results as an InfoWindow</title>
   <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css">
   <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css" />
     <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.5"></script>
    <script type="text/javascript" language="Javascript">
      dojo.require("esri.map");
      dojo.require("esri.tasks.query");
      var map, queryTask, query;
      var symbol, infoTemplate;
      function init() {
        //create map
          basemap: "hybrid",
          zoom: 3
        //create and add new layer
      //var layer1 = new esri.layers.ArcGISDynamicMapServiceLayer("http://crytal1-pc/ArcGIS/rest/services/USA/MapServer");
       //map.addLayer(layer1);
    var layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer");
       map.addLayer(layer);
       //build query task
       queryTask = new esri.tasks.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/2");
       //queryTask = new esri.tasks.QueryTask("http://crytal1-pc/ArcGIS/rest/services/USA/MapServer/2");
        //build query filter
        query = new esri.tasks.Query();
        query.returnGeometry = true;
 query.outFields = ["STATE_NAME", "POP1990"];
        //create the infoTemplate to be used in an InfoWindow.
        //All ${attributeName} will be substituted with the attribute value for current feature.
        infoTemplate = new esri.InfoTemplate("Hello", "State : ${STATE_NAME}<br />Population :");
  //create symbol for selected features
//symbol = new esri.symbol.PictureMarkerSymbol('http://static.arcgis.com/images/Symbols/Basic/YellowStickpin.png', 24, 24);
/*symbol = new esri.symbol.PictureMarkerSymbol({
"angle": 0,
"xoffset": 0,
"yoffset": 12,
"type": "esriPMS",
"url": "http://static.arcgis.com/images/Symbols/Basic/YellowStickpin.png",
"contentType": "image/png",
"width": 24,
"height": 24
  symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NONE, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([123,123,234]), 100), new dojo.Color([123,123,234,0.6]));
   function executeQueryTask(population) {
        //set query based on what user typed in for population;
  //query.where = "POP2000 > " + population;
        query.where = "POP1990 > " + population;
        //execute query and call showResults on completion
        queryTask.execute(query,showResults);
      function showResults(featureSet) {
        //remove all graphics on the maps graphics layer
        map.graphics.clear();
        //QueryTask returns a featureSet.  Loop through features in the featureSet and add them to the map.
  //Performance enhancer - assign featureSet array to a single variable.
  var resultFeatures = featureSet.features;
        for (var i=0, il=resultFeatures.length; i<il; i++) {
          //Get the current feature from the featureSet.
          //Feature is a graphic
          var graphic = resultFeatures;
          graphic.setSymbol(symbol);
          //Set the infoTemplate.
          graphic.setInfoTemplate(infoTemplate);
          //Add graphic to the map graphics layer.
          map.graphics.add(graphic);
  var s = "";
        for (var i=0, il=featureSet.features.length; i<il; i++) {
          var featureAttributes = featureSet.features.attributes;
          for (att in featureAttributes) {
            s = s + "<b>" + att + ":</b>  " + featureAttributes[att] + "<br />";
        dojo.byId("info").innerHTML = s;
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
  <br/>
      US city population greater than : <input type="text" id="population" value="500000" />
    <input type="button" value="Get Details" onclick="executeQueryTask(dojo.byId('population').value);" />
    <div id="mapDiv" style="width:600px; height:600px; border:1px solid #000;"></div>
 Click on a city once it's highlighted to get an InfoWindow.
 <div id="info"></div>
  </body>
</html>
JasonZou
Change esri.symbol.SimpleFillSymbol.STYLE_NONE to esri.symbol.SimpleFillSymbol.STYLE_NULL
LouPhan
I changed it but it could not work. Do I have change something in my layer?
Please help me. Thank you.
JasonZou
When using your map service, does the query return any features back? What's the value of featureSet for showResults? What feature type is your map layer?
