Styling Attribute Inspector in Bootstrap
4190
01-04-2016 05:35 AM
KeithGerhartz1
I am attempting to include the AttributeInspector widget in a Bootstrap app but can't seem to get it to style as expected. Date picker does not appear in a popup, drop downs do not work and the associated fields display as three stacked text boxes, etc.
I know I should not use Claro in combination. Tyring it causes the display to change and improve a bit but still not good and not what should be done in any case.
Any guidance for a Bootstrap newbie?
<Head> listed below. Thanks.
Keith
<head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no">
    <!--    <meta name="description" content="">
    <meta name="author" content="">
    <!-- Safari iOS - apps only -->
    <meta name="apple-mobile-web-app-capable" content="yes">
    <meta name="apple-mobile-web-app-status-bar-style" content="black">
    <!-- Chrome for Android - NEW! -->
    <meta name="mobile-web-app-capable" content="yes">
    <link rel="apple-touch-icon" href="images/brand.png">
    <link rel="shortcut icon" href="images/favicon.ico">
    <title>Bootstrap Map JS - Get Started</title>
    <!-- Bootstrap core CSS -->
    <link href="https://community.esri.com//maxcdn.bootstrapcdn.com/bootstrap/3.3.5/css/bootstrap.min.css" rel="stylesheet">
    <!-- Custom styles for this template -->
    <!-- <link href="css/style.css" rel="stylesheet">-->
    <!-- Bootstrap-map-js -->
    <link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css">
    <link rel="stylesheet" href="https://community.esri.com//esri.github.io/bootstrap-map-js/src/css/bootstrapmap.css">
    <!--<link rel="stylesheet" href="https://js.arcgis.com/3.15/dijit/themes/claro/claro.css">-->
    <style type="text/css">
      #mapDiv {
        min-height: 100%;
        max-height: 100%;
      #search {
         display: block;
    </style>
  </head>
ChrisSmith7
Honored Contributor
Do you have the rest of your code that will highlight your issue? Right off the bat, I do see the href links aren't complete... The browser might resolve them, though.
KeithGerhartz1
Here is the code. Thanks for the quick reply.
<!DOCTYPE html>
<html lang="en">
<head>
      #mapDiv {
        min-height: 100%;
        max-height: 100%;
      #search {
         display: block;
    </style>
  </head>
  <body>
      <div class="panel panel-primary panel-fixed">
          <div class="panel-body">
              <div id="editorDiv"></div>
              <div id="attributeDiv"></div>
          </div>
      </div>
      <div id="mapDiv">
          <img src='images/crosshairs-gray.png' id="findMe" class='find_me' />
      </div>
      <div class="navbar navbar-inverse navbar-fixed-top">
          <div class="container">
              <div class="navbar-header">
                  <button type="button" class="navbar-toggle" data-toggle="collapse" data-target=".navbar-collapse">
                      <span class="icon-bar"></span>
                  </button>
              </div>
              <div class="collapse navbar-collapse">
                  <ul class="nav navbar-nav">
                      <li class="active dropdown" id="basemapList">
                          <a href="" class="dropdown-toggle" data-toggle="dropdown">Maps <b class="caret"></b></a>
                          <ul class="dropdown-menu" id="myDropdown">
                              <li><a href="#">Manage Layers</a></li>
                              <li><a href="#">Use Color Basemap</a></li>
                              <li><a href="#">Use Greyscale Basemap</a></li>
                              <li><a href="#">Use Aerial Basemap</a></li>
                          </ul>
                      </li>
                      <li><a id="geosearchNav" href="#">Search</a></li>
                      <li><a id="aboutNav">About</a></li>
                  </ul>
              </div>
          </div>
      </div>
      <div class="modal fade" id="geosearchModal" style="display: none;" aria-hidden="true">
          <div class="modal-dialog">
              <div class="modal-content">
                  <div class="modal-header">
                      <button type="button" class="close" data-dismiss="modal" aria-hidden="true">X</button>
                      <h4 class="modal-title">Search</h4>
                  </div>
                  <div class="modal-body">
                      <div class="form-group">
                          <div id="search"></div>
                      </div>
                      <form id="geosearch-form" class="form-inline">
                          <button id="btnDismiss" type="submit" class="btn btn-default btn-fixed" data-dismiss="modal">Dismiss</button>
                      </form>
                  </div>
              </div>
              <!-- /.modal-content -->
          </div>
          <!-- /.modal-dialog -->
      </div>
      <div class="modal fade" id="aboutModal" style="display: none;" aria-hidden="true">
                      <h4 class="modal-title">About</h4>
                  </div>
                          <div id="aboutContent"></div>
                      </div>
                      <form id="Form1" class="form-inline">
                          <button id="Button2" type="submit" class="btn btn-default btn-fixed" data-dismiss="modal">Dismiss</button>
                      </form>
                  </div>
              </div>
          </div>
      </div>
      <div class="modal fade" id="layersModal" style="display: none;" aria-hidden="true">
                      <h4 class="modal-title">Layers</h4>
                  </div>
                          <div id="layersContent">vsvvsv</div>
                      </div>
                      <form id="Form2" class="form-inline">
                          <button id="Button1" type="submit" class="btn btn-default btn-fixed" data-dismiss="modal">Dismiss</button>
                      </form>
                  </div>
              </div>
          </div>
      </div>
  </body>
    <script type="text/javascript">
        var package_path = window.location.pathname.substring(0, window.location.pathname.lastIndexOf('/'));
        var dojoConfig = {
            //The location.pathname.replace() logic below may look confusing but all its doing is
            // enabling us to load the api from a CDN and load local modules from the correct location.
            packages: [{
    </script>
    <script src="//js.arcgis.com/3.15"></script>
    <script src="//maxcdn.bootstrapcdn.com/bootstrap/3.3.5/js/bootstrap.min.js"></script>
    <script>
        require([
            "esri/domUtils",
            "dijit/registry",
            "esri/dijit/Popup",
            "esri/InfoTemplate",
            "esri/tasks/IdentifyTask",
            "esri/tasks/IdentifyParameters",
            "esri/dijit/Search",
            "esri/dijit/editing/Editor",
            "esri/dijit/AttributeInspector",
            "esri/dijit/editing/TemplatePicker",
            "esri/layers/GraphicsLayer",
            "esri/tasks/GeometryService",
            "esri/SpatialReference",
            "esri/geometry/Point",
            "esri/map",
            "esri/dijit/BasemapGallery",
            "esri/dijit/BasemapLayer",
            "esri/dijit/Basemap",
            "esri/layers/FeatureLayer",
            "esri/layers/ArcGISTiledMapServiceLayer",
            "esri/dijit/Scalebar",
            "esri/graphic",
            "esri/Color",
            "esri/symbols/SimpleFillSymbol",
            "esri/symbols/SimpleLineSymbol",
            "esri/symbols/SimpleMarkerSymbol",
            "esri/symbols/PictureMarkerSymbol",
            "application/bootstrapmap",
            "dojo/parser",
            "dojo/query",
            "dojo/touch",
            "dojo/dom",
            "dojo/on",
            "dojo/_base/array",
            "dojo/_base/connect",
            "dojo/dom-construct",
            "bootstrap/Modal",
            "bootstrap/Collapse",
            "bootstrap/Dropdown",
            "dojo/domReady!"],
          function (
            domUtils,
            registry,
            Popup,
            InfoTemplate,
            IdentifyTask,
            IdentifyParameters,
            Search,
            Editor,
            AttributeInspector,
            TemplatePicker,
            GraphicsLayer,
            GeometryService,
            SpatialReference,
            Point,
            Map,
            BasemapGallery,
            BasemapLayer,
            Basemap,
            FeatureLayer,
            ArcGISTiledMapServiceLayer,
            Scalebar,
            Graphic,
            Color,
            SimpleFillSymbol,
            SimpleLineSymbol,
            SimpleMarkerSymbol,
            PictureMarkerSymbol,
            BootstrapMap,
            parser,
            query,
            touch,
            dom,
            on,
            arrayUtils,
            connect,
            domConstruct)
              parser.parse();
              var graphic;
              var identifyTask;
              var identifyParams;
              var gsvc = new GeometryService("http://wpk-gis01/arcgis/rest/services/Utilities/Geometry/GeometryServer");
              basemapColor = new ArcGISTiledMapServiceLayer("http://wpk-gis01/arcgis/rest/services/BaseMapColor/MapServer");
              basemapGreyscale = new ArcGISTiledMapServiceLayer("http://wpk-gis01/arcgis/rest/services/BaseMapGreyscale/MapServer");
              basemapAerial = new ArcGISTiledMapServiceLayer("http://wpk-gis01/arcgis/rest/services/Aerials/MapServer");
              var myLocationLayer = new GraphicsLayer({ id: "location" });
              var map = BootstrapMap.create("mapDiv", {
                  zoom: 0
              var currentBasemap = []
              currentBasemap.push(basemapColor);
              map.addLayer(basemapColor);
              map.reorderLayer(basemapColor, 0);
              var scalebar = new Scalebar({
                  map: map,
                  scalebarUnit: "dual"
              //query("#layersContent").replaceWith("test");
              //query("#layersModal").modal("show");
              map.addLayer(myLocationLayer);
              map.on("layers-add-result", initEditor);
              var incidentLayer = new FeatureLayer("http://wpk-gis01/arcgis/rest/services/InfoShare_DataEditing/FeatureServer/0", {
                  mode: FeatureLayer.MODE_ONDEMAND,
                  outFields: ["*"], id: "incidentLayer"
              //incidentLayer.setSelectionSymbol(new SimpleMarkerSymbol().setColor(new Color("red")));
              map.addLayers([incidentLayer]);
              var incidentCommentsLayer = new FeatureLayer("http://wpk-gis01/arcgis/rest/services/InfoShare_DataEditing/FeatureServer/1", {
                  outFields: ["*"], id: "incidentCommentsLayer"
              function initEditor(evt)
                  var layers = arrayUtils.map(evt.layers, function (result)
                      return { featureLayer: result.layer };
                  var attributeInspector = new AttributeInspector({ layerInfos: layers }, "attributeDiv");
                  var settings = {
                      attributeInspector: attributeInspector,
                      map: map,
                      layerInfos: layers,
                      toolbarVisible: false
                  var params = { settings: settings };
                  var myEditor = new Editor(params, 'editorDiv');
                  myEditor.startup();
              //map.on("load", mapReady);
              //var parcelsURL = "http://wpk-gis01/arcgis/rest/services/BaseMapGreyscale/MapServer";
              //function mapReady()
              //    map.on("click", executeIdentifyTask);
              //    identifyTask = new IdentifyTask(parcelsURL);
              //    identifyParams = new IdentifyParameters();
              //    identifyParams.tolerance = 3;
              //    identifyParams.returnGeometry = true;
              //    identifyParams.layerIds = [3, 20];
              //    identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_VISIBLE;
              //    identifyParams.width = map.width;
              //    identifyParams.height = map.height;
              //function executeIdentifyTask(event)
              //    identifyParams.geometry = event.mapPoint;
              //    identifyParams.mapExtent = map.extent;
              //    var deferred = identifyTask
              //      .execute(identifyParams)
              //      .addCallback(function (response)
              //          return arrayUtils.map(response, function (result)
              //              var feature = result.feature;
              //              var layerName = result.layerName;
              //              feature.attributes.layerName = layerName;
              //              if (layerName === 'Parcels - Orange')
              //                  var infoTemplateParcel = new InfoTemplate("Parcel",
              //                    "${PARCEL}");
              //                  feature.setInfoTemplate(infoTemplateParcel);
              //              else if (layerName === 'Cities - Orange')
              //                  var infoTemplateCities = new InfoTemplate("Cities",
              //                    "${CITY_NAME}");
              //                  feature.setInfoTemplate(infoTemplateCities);
              //              return feature;
              //    map.infoWindow.setFeatures([deferred]);
              //    map.infoWindow.show(event.mapPoint);
              function changeLayer(layerName)
                  map.removeLayer(currentBasemap[0])
                  currentBasemap.length = 0;
                  currentBasemap.push(layerName)
                  map.addLayer(layerName)
                  map.reorderLayer(layerName, 0);
              function findMe()
                  var options = {
                      enableHighAccuracy: true,
                      timeout: 5000,
                      maximumAge: 0
                  if (navigator.geolocation)
                      navigator.geolocation.getCurrentPosition(
                      function (position)
                          var pointin = new Point(position.coords.longitude, position.coords.latitude, new SpatialReference({
                              wkid: 4326
                          gsvc.project([pointin], new SpatialReference({ wkid: 2236 }), function (projectedPoints)
                              var pt = projectedPoints[0];
                              var graphic = new Graphic(pt, new PictureMarkerSymbol('images/i_target.png', 38, 38));
                              myLocationLayer.add(graphic);
                              map.centerAndZoom(pt, 5);
                          var interval = setInterval(function ()
                              clearInterval(interval);
                              map.getLayer('location').clear();
                          }, 5000);
                      }, function (err)
                          console.warn('ERROR(' + err.code + '): ' + err.message);
                      }, options);
                  else
                      alert("Browser doesn't support Geolocation. Visit http://caniuse.com to see browser support for the Geolocation API.");
              //UI EVENTS
              var s = new Search({
                  map: map,
                  enableHighlight: false
              }, "search");
              s.startup();
              on(s, 'select-result', function (e)
                  query("#geosearchModal").modal("hide");
              query("#basemapList li").on(touch.press, function (e)
                  e.preventDefault();
                  switch (e.target.text)
                      case "Use Color Basemap":
                          changeLayer(basemapColor);
                          break;
                      case "Use Greyscale Basemap":
                          changeLayer(basemapGreyscale);
                          break;
                      case "Use Aerial Basemap":
                          changeLayer(basemapAerial);
                          break;
                      case "Manage Layers":
                          collapseNavbarAfterSelection(e);
                          break;
              query("#findMe").on(touch.press, function (e)
                  e.preventDefault();
                  findMe();
              query("#geosearchNav").on('click', function (e)
                  query("#geosearchModal").modal("show");
              query("#aboutNav").on('click', function (e)
                  query("#aboutModal").modal("show");
              function collapseNavbarAfterSelection(e)
                  if (query(".navbar-collapse.in").length > 0)
                      e.stopPropagation();
                      query(".navbar-toggle")[0].click();
                  } else
    </script>
</html>
ChrisSmith7
Honored Contributor
Are you sure your bootstrap module is sourced correctly? It seems to be throwing a 404 for me.
KeithGerhartz1
Not getting an error here.
