Style on InfoWindow is offset by 1000px
947
12-03-2010 06:44 AM
JasonFoster
Style on InfoWindow is offset by 1000px to the left when the window is shown on the right
xmin=&xmax=&ymin=&ymax=
HTML CODE
 <div id="photomap" style="width:650px; height:550px; "></div>
JAVASCRIPT :
var map, ymax, xmax, ymin, xmin, abbr, startExtent;
var baseUrl, dataUrl;
var baseLayer, dataLayer, infoLayer;
var geometryService;
function initMap() {
        xmin = -9823416;
        ymin = 5142818;
        xmax = -9821853;
        ymax = 5143771;
    // contains images
    var json = "images": { "image": [
            "X": -9822278.67157321,
            "Y": 5143567.12522437
            "X": -9822700.448755,
            "Y": 5143231.12358844
        {  "X": -9822728.89706931,
            "Y": 5143230.29294391
        {  "X": -9822475.64522776,
            "Y": 5143564.63320335,  } ] } }
    startExtent = new esri.geometry.Extent(xmin, ymin, xmax, ymax, new esri.SpatialReference({ wkid: 102100 }));
    map = new esri.Map("photomap", { extent: startExtent });
    // Get Url
    baseUrl = "http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer";
    dataUrl = "http://crsgis.crsengineers.com:1771/ArcGIS/rest/services/AWCH/MapServer";
    // Create layers
    baseLayer = new esri.layers.ArcGISTiledMapServiceLayer(baseUrl);
    dataLayer = new esri.layers.ArcGISDynamicMapServiceLayer(dataUrl);
    // Add Layers
    map.addLayer(baseLayer);
    map.addLayer(dataLayer);
    map.infoWindow.resize(245, 150);
    dojo.connect(map, "onLoad", function() {
        if (json != null) {
            var jsonData = eval("(" + json + ")");
            loadImagesPoints(jsonData);
function loadImagesPoints(json) {
    var images = json.images.image;
    var imageCount = images.length;
    for (var a = 0; a < imageCount; a++) {
        var image = images;
        //var point = new esri.geometry.Point({ "x": parseFloat(image.UTMEasting), "y": parseFloat...
this is what it looks like if I apply the style
.infowindow .window { position:relative; }
