Stuck on getting getResultImageLayer
7127
27
10-24-2012 11:22 AM
SmaranHarihar
I am getting back the success from the GP Tool but for some reason, when I execute the,
gp.getResultImageLayer(jobInfo.jobId,"final_shp", imageParams, function(gpLayer) {    map.addLayer(gpLayer);     });
I am receiving an error on the map.addLayer(gpLayer). The error is,
Network Error: 500 Internal Server Error - <complete path of the job directory where the final.shp is created>. What is causing the layer not to be added to the Map? This is the link.
This is my code,
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html>          <head>         <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />         <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />         <!--The viewport meta tag is used to improve the presentation and behavior         of the samples on iOS devices-->         <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"         />         <title>GP Viewshed Task</title>         <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/dojo/dijit/themes/claro/claro.css">         <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css"         />         <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2compact"></script>         <script type="text/javascript">             dojo.require("esri.map");             dojo.require("esri.tasks.gp");             dojo.require("esri.layers.FeatureLayer");             dojo.require("esri.dijit.Popup");             dojo.require("dijit.TooltipDialog");              var map, gp, featureLayer, dialog;              /*Initialize map, GP*/             function init() {                 var startExtent = new esri.geometry.Extent({                     "xmin": -13644840.338547781,                     "ymin": 4529944.368315823,                     "xmax": -13614265.527233753,                     "ymax": 4552875.476801345,                     "spatialReference": {                         "wkid": 102100                     }                 });                  map = new esri.Map("mapDiv", {                     extent: startExtent                 });                 var streetMap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");                 map.addLayer(streetMap);                 //http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Network/ESRI_DriveTime_US/GPServer/CreateDriveTimePolygons (Drive Time Polygons)                 gp = new esri.tasks.Geoprocessor("http://webgis.arizona.edu/ArcGIS/rest/services/webGIS/Shock_Models/GPServer/Income_Log");                  gp.setOutputSpatialReference({                     wkid: 102100                 });                 dojo.connect(map, "onClick", computeViewShed);                 }              function computeViewShed(evt) {                 map.graphics.clear();                 if (map.graphicsLayerIds.length >= 1) {                     map.removeLayer(map.getLayer(map.graphicsLayerIds[0]));                 }                 var pointSymbol = new esri.symbol.SimpleMarkerSymbol();                 pointSymbol.setSize(20);                 pointSymbol.setOutline(new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0, 0, 0]), 1));                 pointSymbol.setColor(new dojo.Color([0, 0, 255, 0.25]));                  var graphic = new esri.Graphic(evt.mapPoint, pointSymbol);                 map.graphics.add(graphic);                  var features = [];                 features.push(graphic);                 var featureSet = new esri.tasks.FeatureSet();                 featureSet.features = features;                 var params = {                     "Input_Feature_Layer": featureSet,                     "Expression": "50"                 };                 //gp.execute(params, drawViewshed);                 gp.submitJob(params, completeCallback, statusCallback, function (error) {                     alert(error);                     //esri.hide(loading);                 });              }              function completeCallback(jobInfo) {                 if (jobInfo.jobStatus !== "esriJobFailed") {                     //gp.getResultData(jobInfo.jobId,"Output_Polygons", downloadFile);                     var imageParams = new esri.layers.ImageParameters();                     imageParams.imageSpatialReference = map.spatialReference;                     gp.getResultImageLayer(jobInfo.jobId, "final.shp", imageParams, function (gpLayer) {                         map.addLayer(gpLayer);                     });                 }             }               function statusCallback(jobInfo) {                 var status = jobInfo.jobStatus;                 if (status === "esriJobFailed") {                     alert(status);                     //esri.hide(loading);                 } else if (status === "esriJobSucceeded") {                     console.log("Success");                     //esri.hide(loading);                 }             }              dojo.addOnLoad(init);         </script>     </head>          <body class="claro">         <div id="mapDiv" style="width:800px; height:600px; border:1px solid #000;"></div>Click on map to execute my GP Task.</body>  </html>
nicogis
I see error:
Server Error - Object reference not set to an instance of an object when it's request image from mxd.
Have you set in gp service the Result Map Service of MapServer ?
Can you open request with support esri? it's difficult if I don't see model (settings, variable scratch ect.)
nicogis
if I see log with a sample request (via browser)
http://webgis.arizona.edu/ArcGIS/rest/services/webGIS/Shock_Models/GPServer/Income_Log/submitJob?Inp...
I see that output isn't in arcgisjobs but in your temp so it isn't accessible. Have you set variable stratchworkspace ? Name of Parameter output is final_shp (I see in code final.shp) and set it esriGPParameterTypeRequired.
SmaranHarihar
I apologize for the late response. Thank you for your reply. When I remotely log into the server and check for the jobs folder I am able to see the shapefile (final_shp) and it also has the results which I wish to display. The server wipes out all the job folders that were created at the end of the day. Here is the new job folder link and I am also able to see all the details of the output shapefile in this link as well.
I changed the final.shp to final_shp. My FLEX application uses the same GP Tool with the same settings and displays the output but I am not able to replicate it on Javascript.
Also this is the error that appears in the console,
  "NetworkError: 500 Internal Server Error - http://webgis.arizona.edu/ArcGIS/rest/services/webGIS/Shock_Models/GPServer/Income_Log/jobs/jc47c82f...
nicogis
Have you details in log of rest, in event viewer windows and in iis?
SmaranHarihar
Can you help me locate them? Not sure which are the files that I need to look into.
SmaranHarihar
I tried it through fiddler and this was the output that I got for the 500 error,
SESSION STATE: Done.
Response Entity Size: 849 bytes.
== FLAGS ==================
BitFlags: [ClientPipeReused, ServerPipeReused] 0x18
X-CLIENTPORT: 2010
X-RESPONSEBODYTRANSFERLENGTH: 849
X-EGRESSPORT: 2023
X-HOSTIP: 128.196.53.161
X-PROCESSINFO: firefox:2248
X-CLIENTIP: 127.0.0.1
X-SERVERSOCKET: REUSE ServerPipe#2
== TIMING INFO ============
ClientConnected: 15:53:51.383
ClientBeginRequest: 15:53:51.494
GotRequestHeaders: 15:53:51.494
ClientDoneRequest: 15:53:51.494
Determine Gateway: 0ms
DNS Lookup:   0ms
TCP/IP Connect: 0ms
HTTPS Handshake: 0ms
ServerConnected: 15:52:45.077
FiddlerBeginRequest: 15:53:51.495
ServerGotRequest: 15:53:51.495
ServerBeginResponse: 15:53:51.679
GotResponseHeaders: 15:53:51.679
ServerDoneResponse: 15:53:51.679
ClientBeginResponse: 15:53:51.679
ClientDoneResponse: 15:53:51.679
 Overall Elapsed: 00:00:00.1850106
The response was buffered before delivery to the client.
== WININET CACHE INFO ============
This URL is not present in the WinINET cache.
* Note: Data above shows WinINET's current cache state, not the state at the time of the request.
* Note: Data above shows WinINET's Medium Integrity (non-Protected Mode) cache only.
nicogis
I see error:
SmaranHarihar
Hey ciava,
Thank you so much for your help. Actually there was some problem with the Geoprocessing Tool and I was finally able to resolve it.
Here is my application. You can place one or more points and it works great. It will take around 20-25 sec.
Just one more question.
If I want to create popups for gplayer how can I do that?
nicogis
Well I am happy for you!
If I have understand your question: see this sample http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples/map_dialog.html
SmaranHarihar
Thanks again for the reply ciava. I actually wanted to display the information that the 'gplayer' has, which I am receiving from the getResultImageLayer.
So now that I have added the layer onto the map, I wish to fetch the content details of the gpLayer. There are four main fields that gpLayer has and I want to add it to the popup info.
Like in the example you gave, which displays the Lat and Long, I wish to use the same popup feature but instead of Lat and Long in contents, I want to display the data in the gpLayer.
I hope I was able to explain well.
