Strange map behavior with API version 3.0 and above
2596
6
05-13-2013 11:48 AM
AshishArora
Hello
I am facing a very strange behavior with map when using with Telerik Kendo Mobile. I have created a JSbin link to reproduce the issue.
Link: http://jsbin.com/ucupal/1/edit
Issue: When using ArcGIS api for Javascript version 3.0 and above with Telerik Kendo Mobile, Map disappears in specific cases but with version 2.8 of API map continues to display.
How to reproduce problem on Iphone  using the code provided in above jsbin link:
1). After running the above code on your device, Click Info ("i") button placed in NavBar. This will navigate to another view where you will find Input type search and one back button.
2). If you click back button, it will navigate back to main view and will show map but if you type something using IOS keyboard in search box and then click back button, you will not find map anymore.
I tried the same process with API version 2.8 and it works but not for versions above 3.0.
Any Ideas / suggestions .
Thanks
Ashish...
JeffJacobson
This is a known issue that also occurs with jQuery UI and other platforms.  There is a workaround, though.
ArielIllouz
Hello Ashish,
Recently i encountered with the same behavior you describe here with kendo mobile and esri map. So, the map view is blank after edit some data from different view and going back to the map. Do you have some workaround for that ? i'm using esri 3.9
Note - the workaround hyperlink Jeff post here is broken.
Thank you,
Ariel
JeffJacobson
I've fixed the broken link in my earlier post above.
ArielIllouz
thank you Jeff, this is very helpfull
AshishArora
Hello Ariel
The issue was not only related to edit but also with the rotation where you get blank map once you return from another view.
Actually, whenever you return to the map view, you will find the height and width of map become zero because of which no map in the view.
You need to resize and reposition the map.
ArielIllouz
yea, got it...thanks.
