Strange Magic In Layer List ... Bug?
3778
11
11-09-2018 05:56 AM
JohnRichardson
I have an application that has 4 layers that I want to stay available in my map at all times. In my layer list, they appear as follows:
The code that creates the layers follows:
var featurelayer = new FeatureLayer({ //adds a feature layer of 2018 Crime
 url: "http://172.20.25.165:6080/arcgis/rest/services/Crime2018_110218/FeatureServer",
 title: "2018 Crime",
 renderer: crimeRenderer,
 visible: false,
 popupEnabled: false,
 popupTemplate: crimePopupTemplate
 map.add(featurelayer, 2);
 var apdbeatsLayer = new FeatureLayer({ //adds a feature layer of APD Beats
 url: "http://172.20.25.165:6080/arcgis/rest/services/APD_Beats_Feature/FeatureServer",
 title: "APD Beats",
 renderer: beatsRenderer,
 popupTemplate: beatsPopupTemplate,
 opacity: 0.5,
 visible: false
 map.add(apdbeatsLayer, 3);
 var orthLayer = new ImageryLayer({ //adds an image layer of Orthos SCE
 url: "http://172.20.25.165:6080/arcgis/rest/services/Ortho_SCE/ImageServer",
 title: "Ortho - East",
 visible: false
 map.add(orthLayer, 0);
 var orthLayer2 = new ImageryLayer({ //adds an image layer of Orthos SCW
 url: "http://172.20.25.165:6080/arcgis/rest/services/Ortho_SCW/ImageServer",
 title: "Ortho - West",
 visible: false
 map.add(orthLayer2, 1);
At any time, the user may choose a month from a menu, and a query runs against the 'featurelayer' and then displays only the crimes for that month in a new featurelayer :
Here you can see that I have added 4 months of crime data to the map, each layer a different color, and you can also see the layers show up in the layer list :
I have a radial menu, which has an icon to click to remove any added layers from the layer list, as it can get crowded quick:
The icon code for removing the added layers, and leaving the 4 default layers is as follows:
$("#ichyPic").click(function() {
 var layLength = map.layers.length;
 /*alert(layLength);
 map.layers.removeAll();*/
 while (layLength > 4) {
 map.layers.removeAt(layLength-1);
 layLength--;
If 4 or more layers have been added to the map, the code above eliminates all of the layers,but still leaves a straggler behind, at the bottom of the layer list ... this layer, as you can see in the picture below, is turned on, but nothing shows on the map ... the layer is not real, it just shows up ... I think this may be a bug?
Thank you!
RobertScheitlin__GISP
John,
  Your best bet it to develop a simplified as possible sample that you can share with esri tech support when you call then.
JohnRichardson
Robert ... will do ... I will create a fiddle or something
Thanks for looking at this
