Stop zomming in behind certain scale - Level 19 - Using world topo basemap
3142
03-17-2016 12:35 PM
GabiVoicu
Is there a way to stop/block zooming in behind a certain scale - Level 19 - while using the word topo as a basemap ?
here is an example where we would like to stop at an earlier level than the world topo
Collin County Interactive Maps
Thank you
Tags (1)
RobertScheitlin__GISP
Gabi,
  Sure you just specify the "lods" for your basemap topo when you define your map constructor.
Go to this link and then scroll down till you find lods:
Map | API Reference | ArcGIS API for JavaScript
There is some example syntax there.
Gabi,
GabiVoicu
Thank you so very much Robert that worked beautifully !
ReneRubalcava
Esri Frequent Contributor
You can set the maxZoom of the map to prevent it from zooming past a certain level.
var map = new Map("map", {
  basemap: "topo",
  center: [-122.45, 37.75],
  zoom: 13,
  maxZoom: 15
sample app
JS Bin - Collaborative JavaScript Debugging
