SsnappingManager only snaps to map graphics
2437
6
04-17-2013 06:13 AM
AdrianMarsden
Honored Contributor
Hi
I have a internal project about to go live, I really want to have snapping for measurements and user added graphics.
At the moment a simple
    map.enableSnapping({ snapKey: dojo.keys.copyKey });
gets it on. However snapping only appears to work against already drawn graphics, not on any of my vector layers on my map.  My map is made up of four ArcGISDynamicMapServiceLayer - added like this
    var background = new esri.layers.ArcGISDynamicMapServiceLayer(mapservice1, { "id": "mainbasemaps" });   // map.addLayer(background);       background.setDPI(150);     var altmaps = new esri.layers.ArcGISDynamicMapServiceLayer(altbasemaps, { "id": "altbasemaps" });    // map.addLayer(altmaps);     var aerials = new esri.layers.ArcGISDynamicMapServiceLayer(aerialservice, { "id": "aerialmaps" });       //map.addLayer(aerials);     dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer(mapservice2, { "id": "mainmap" });     dynamicMapServiceLayer.setOpacity(0.9);     dynamicMapServiceLayer.setDPI(96)     map.addLayers([background],[altmaps],[aerials],[dynamicMapServiceLayer]);
from the API documentation
Reference to a feature or graphics layer that will be a target snapping layer. The default option is to set all feature and graphics layers in the map to be target snapping layers.
So I would have thought it would snap to everything?
I've tried defining a specific layer like
var snappinglayer = new esri.layers.FeatureLayer(mapservice2 + "/4", {        mode: esri.layers.FeatureLayer.MODE_ONDEMAND,         outFields: ["*"]     }); ... var layerInfos = [{ layer: snappinglayer }];     snapManager.setLayerInfos(layerInfos);
But that fails.
Any ideas what I've missed?
ACM
JianHuang
Yes, the featureLayer has to be added to the map and it has to be visible.
Ah, do I understand correctly then, that the snapping only works on feature layers added to the map?  I guess so
If so it would explain a lot as I have no feature layers, just dynamic ones.
So, if  I add a feature layer to the map - does it have to be visible?
Cheers
ACM
JohnGravois
im not sure i understand.  are you trying to snap to a featureLayer which hasn't been added to the map because youre already drawing it in a DynamicMapServiceLayer?
AdrianMarsden
Honored Contributor
Cheers
ACM
JohnGravois
i haven't done any testing with this at all, but my guess would be that only the graphics being drawn would be "snap enabled".
JianHuang
Cheers
ACM
AdrianMarsden
Honored Contributor
Cheers - I'm sure I tried that, but I'll have another go.
Thanks
ACM
AdrianMarsden
Honored Contributor
sorted - thanks - I must have read the API notes several times without noticing it said feature.
Cheers
ACM
