Spatial relationship touches
1973
06-14-2011 09:41 PM
DemyanovaElena
Hi! Glad to use this forum! I have a question for experts.
How can I use JScript API ArcGIS Server to get polygons ID that touch to the selected polygon?
Thanks a lot for your time!
HemingZhu
Not sure exactly what your situation is , there are a couple of ways to achieve your goal throught JS API. GeometryService.relation(relationParameters, callback?, errback?) computes the two sets of geometries that belong to the specified relation, you could specify the relationParams.relation constant to the relationship you would like to compute (SPATIAL_REL_LINETOUCH or specify SPATIAL_REL_RELATION); Or you could do a QueryTask using a spatial filter (esri.tasks.Query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_TOUCHES or specify SPATIAL_REL_RELATION), it find out the feature(s) from one layer (or graphic(s)) touches the border of feature(s) from another layer.
derekswingley1
The Query for polygon and adjacent polygons sample sounds like it fits your needs. Note the part about the proxy, that trips up a quite a few people.
nicogis
Extra info:
if you need custom spatial relationship you can use scl in api esri:
http://nicogis.blogspot.com/2011/02/scl-da-client.html
In your case:
The size of the intersection of G1 and G2 is not nothing.
The size of the intersection and G1.interior G2.interior is nothing
TOUCH G1 G2 is then equivalent to saying that dim (g1.interior, g2.interior) = null and dim (g1, g2)! = Null
All the following examples are equivalent (because the SCL syntax to inherit and CBM):
G1 TOUCH G2
G1 TOUCHES G2
G1 =* G2
TOUCH (G1,G2) = TRUE
TOUCHES (G1,G2) = TRUE
for use scl in  http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/relationparameters.htm
use SPATIAL_REL_RELATION
DemyanovaElena
Oh, thanks! This is what I need.
I was so inattentive that didn't see this example! Try to correct! 🙂
