SourceCountry parameter has no effect in Geocoder
1132
08-21-2014 06:33 AM
JamesSampica
Using this sample...
ArcGIS API for JavaScript Sandbox
change the geocoder as follows...
    geocoder = new Geocoder({
          autoComplete: true,
          map: map ,
          arcgisGeocoder: {
                    sourceCountry: "USA"
    }, "search");
typing anything into the geocoder still causes it to match addresses from other countries.
Is there a workaround for this?
JoshHevenor
This has kind of worked for me (taken from an older forum post by Joanne McGraw that I can't find):
            var geocoders = [{
                url: "some/geocoder",
                name: "EC Geocoder",
                singleLineFieldName: "SingleLine",
                suffix: ", CA" // Canada <-------------------------
          var geocoder = new Geocoder({
                map: map,
                geocoders: geocoders,
                arcgisGeocoder: false,
                autoComplete: true
            }, dojo.create('div'));
I've also have tried keeping a polygon of the country of origin handy, and filtering the Geocoder results using Polygon.contains(point) for a client-side check.
