Some general questions...........
987
04-15-2010 09:34 AM
ZlatkoGrebenar1
I'm just diving into the Javascript API so I just need some help...........
Where do you go to upgrade to the newest version ? I'm using the sample viewer 1.2 currently and wanted to upgrade to 1.6.
I have worked with Flex API in the past and I know I had to use WGS 84 projection for all layers. It seems to me that I will have to do follow the same method with the Javascript API?
I have noticed that some of the widgets don't work out of the box do I need to change any settings with the config json files?
That's it for now..
