slider for change transparency mapservice with jquery mobile
2213
10-03-2013 07:06 AM
francescodi_vito
hi guys
i'm developing a mobile app with jquery mobile and api javascript compact.
I create a list of map service with checkbox to show / hide.
Now i would like to develop a slider for change transparency but my code don't work
This is the code for slider
$(document).ready(function(){
$("#slider-id").slider({
    value:100,
    min:0,
    max:100,
    step:5,
    slide : function(evt, ui){
     featureLayerB.setOpacity(ui.value/100);
and my jquery slider:
<input type="range" id="slider" data-mini="true">
but don't work. Any idea or any help?
Any example?
thanks
Bye
JonathanUihlein
I'd need to see more code to be able to give specific advice. It's very hard to tell from this small code snippet.
Otherwise, here are some questions:
Does the slider function work (outside of changing the transparency)?
Are you able to change the transparency directly, without the slider?
Have you used a try/catch to identify where the problem occurs?
Is there an error message?
And lastly, can you replicate your issue in a http://jsfiddle.net/ ?
francescodi_vito
hi jon,
thanks for your reply.
This is my code:
[HTML]
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9, IE=10">
<!-- Sets whether a web application runs in full-screen mode. -->
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0">
<!-- Sets the style of the status bar for a web application. -->
<meta name="apple-mobile-web-app-status-bar-style" content="black-translucent">
<title>Mobile Gallery</title>
<link rel="stylesheet" href="http://code.jquery.com/mobile/1.3.0/jquery.mobile-1.3.0.min.css" />
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css" />
<style type="text/css">
  html, body
        height: 100%;
        margin: 0px;
        padding: 0px;
        width: 100%;
   #mapcontent, #map { width: 100%; height: 100%; padding: 0; position: absolute; z-index: 0;}
    </style>
<script src="http://code.jquery.com/jquery-1.9.0.min.js"></script>
<script src="http://code.jquery.com/mobile/1.3.0/jquery.mobile-1.3.0.min.js"></script>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5compact/"></script>
<script>
  dojo.require("esri.map");
  dojo.require("esri.layers.ArcGISDynamicMapServiceLayer");
  var featureLayerB;
  var featureLayerA;
    var map;
   function init() {
    map = new esri.Map("map", {
      center: [12.785, 42.372],
      zoom: 4,
      basemap: "streets"
    featureLayerB = new esri.layers.ArcGISDynamicMapServiceLayer("http://www.pcn.minambiente.it/arcgis/rest/services/geologica/MapServer",
    visible:false}
    featureLayerA = new esri.layers.ArcGISDynamicMapServiceLayer("http://sgi.isprambiente.it/ArcGIS/rest/services/servizi/elementi_idrografici/MapServer",
    visible:false}
    map.addLayer(featureLayerB)
    map.addLayer(featureLayerA)
function updateLayerVisibility() {
  var isChecked = $('#checkbox-v-2a').is(':checked');
  if(isChecked == true){
  featureLayerB.show()
  else{
  featureLayerB.hide()
function updateLayerVisibility_1() {
  var isChecked = $('#checkbox-v-2b').is(':checked');
  featureLayerA.show()
  else{
  featureLayerA.hide()
  dojo.ready(init);
</script>
</head>
<body>
<!-- home view -->
<div data-role="page" id="home">
  <!-- header -->
  <div data-theme="a" data-role="header" data-position="fixed">
  <a href="#toc" data-role="button" data-icon="bars" data-iconpos="notext"></a>
    <h3>Editing</h3>
  </div>
  <!-- content -->
  <div data-role="content" id="mapcontent">
    <div id="map"></div>
  </div>
</div>
<!-- layer view -->
<div data-role="page" id="toc">
  <!-- header -->
  <a href="#home" data-role="button" data-icon="back" data-iconpos="notext"></a>
    <h3>Layer</h3>
  </div>
  <!-- content -->
  <div data-role="content">
    <form>
    <fieldset data-role="controlgroup">
        <legend>Vertical:</legend>
        <input type="checkbox" name="checkbox-v-2a" id="checkbox-v-2a" onClick="updateLayerVisibility()">
</form>
<form>
</form>
<form>
        <label for="checkbox-v-2a">Operation Layer 1</label>
        <input type="checkbox" name="checkbox-v-2b" id="checkbox-v-2b" onClick="updateLayerVisibility_1()">
        <label for="checkbox-v-2b">Operation Layer 2</label>
        <input type="checkbox" name="checkbox-v-2c" id="checkbox-v-2c">
        <label for="checkbox-v-2c">Operation Layer 3</label>
    </fieldset>
</form>
  </div>
</div>
</body>
</html>
[/HTML]
With the debuger of chrome i don't see nothing when i use the slider.
Thanks for your interest and help
Bye
RobertMEIER
i am stuck at the exact same place, have you solved this yet?
SteveCole
Honored Contributor
I'm going to half to tackle this at some point in the near future myself. When I look at the API documentation, it kinda looks like you could just use a bind on the "change" event. So, from Francesco's example, it would be something like-
$( "#slider-id" ).bind( "change", function(event, ui) {
Steve
