SketchViewModel.pointSymbol support for PictureMarkerSymbol
1612
08-23-2019 09:59 AM
Alexander__Contractor_Schrimpf
I have a feature layer that uses PictureMarkerSymbols as the map markers. When I move the feature I can only get the SketchViewModel.pointSymbol to be either SimpleMarkerSymbol or PointSymbol3D as described in the api documentation here:  https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Sketch-SketchViewModel.ht...
Is there a technical limitation for not being able to use PictureMarkerSymbols? Is there any way I could extend arcgis js api's current functionality to allow this?
UndralBatsukh
Hi there,
You cannot change the update graphic for SketchViewModel at this time. It is on our to do list. However, I do not have a timeline for this.
-Undral
In case anyone else needs this functionality this hack somewhat works...
   const editingLayer = new GraphicsLayer();
    const map = new Map({
      basemap: new Basemap({
        baseLayers: [baseMapLayer]
      layers: [featureLayereditingLayer]
    const view = new MapView({
      map,
      container: this.$refs.map
    const sketchViewModel = new SketchViewModel({
      layer: editingLayer,
      view,
      updateOnGraphicClick: true
    sketchViewModel.on("update"async event => {
      if (event.state === "start") {
        await Promise.all(
          event.graphics.map(async (graphic: esri.Graphic=> {
            const [PictureMarkerSymbol= (await loadModules([
              "esri/symbols/PictureMarkerSymbol"
            ])) as [esri.PictureMarkerSymbolConstructor];
            graphic.symbol = new PictureMarkerSymbol({
              url: require(`../assets/map_icons/${-1}_${
                graphic.attributes.FCODE
              }_solid_black.svg`),
              height: 23,
              width: 23
    view.on("click"event => {
      if (sketchViewModel.state === "active") {
        return;
      view.hitTest(event).then(({ results }) => {
        results
          .filter(x => x.graphic.layer === featureLayer)
          .forEach(async result => {
            editingLayer.add(result.graphic);
            await sketchViewModel.update(result.graphic, {
              tool: "move",
              toggleToolOnClick: false
