Show pie-chart values & legend in info-window for AGS_JSAPI 3.4/3.5
715
07-19-2013 08:58 PM
SunilPalkar
Currently I am going through this example and trying to insert values in pie chart (I have added that screenshot and want to show values & legend in the info window)
I am using ArcGIS Suit 10.1 and ArcGIS JSPAI version 3.5
What I have tried:
-Tried to insert values in media-info but it is not representing in pie-chart.
-Tried this dojo-example link
Any help regarding this will be great
Thanks in advance : )
KellyHutchins
Esri Notable Contributor
Sunil,
Here's a sample that uses media infos with a bar chart instead of a pie chart but shows the general steps. After reviewing the sample if you are still having issues with your application perhaps you can post some sample code so we can see what you are doing.
https://developers.arcgis.com/en/javascript/jssamples/popup_chart.html
