show numeric scale for ArcGISDynamicMapServiceLayer?
1356
11-21-2011 11:58 AM
SteveCole
Honored Contributor
I'd like to display a numeric scale value while using a ArcGISDynamicMapServiceLayer but the only code examples I've been able to find so far relate to using an ArcGISTiledMapServiceLayer in which the LOD has a scale property.
Can this be done with ArcGISDynamicMapServiceLayers and does anyone have an example they can share?
Thanks!
Steve
JianHuang
Steve,
It depends on the spatial reference, DPI and other factors. The easiest way probably is to add a scalebar on your map and exact the scale value from it:
var scalebarLengthInPixel = scalebar.domNode.style.width; // For example, you may get "112px" as returned value
var scalebarLengthInReality = dojo.query(".esriScalebarSecondNumber", scalebar.domNode)[0].innerHTML; //you may get "300mi" as returned value
Then, parse both values to numbers and calculate the scale value. For example, scalevalue = 300*1609*39.3700787*96/112  (1 mi = 1609 meters, 1 meter = 39.3700787 inches, and assuming the client DPI is 96)
If you don't like a visible scalebar, you can always call
esri.hide(scalebar.domNode); to hide it.
Hope this helps.
JeffMitzelfelt
I calculate my scale on an onExtentChange event using the XY dimensions of the map object (returned by the onExtentChange event) and the size of the mapDiv.
dojo.connect(map, "onExtentChange", updateExtent);
dojo.connect(window, 'resize', mapResize);
pixelPerMeter = 96/.0254; // Define pixel per meter value (96 pixels per inch)
function mapResize(){
 var resizeTimer;
 clearTimeout(resizeTimer);
 resizeTimer = setTimeout(function(){
  sizeMap();
  map.resize();
  map.reposition();
  }, 500);
function sizeMap(){
 mapWidthPx = window.innerWidth;
 // Using 57 pixels for control/information bars
 mapHeightPx = window.innerHeight - 57;
 // Set calculated height for mapDiv
 $("#map").css({"height" : (mapHeightPx + "px")});
function updateExtent(evt){
 mapScale = calcScale(evt.xmax, evt.xmin, evt.ymax, evt.ymin);
 displayMapScale(mapScale); // Write map scale out to
function calcScale(maxX, minX, maxY, minY) {
 var meterX = Math.abs(maxX - minX);
 var meterY = Math.abs(maxY - minY);
 var scaleX = meterX / mapWidthPx * pixelPerMeter;
 var scaleY = meterY / mapHeightPx * pixelPerMeter;
 var scaleMin = Math.round((scaleY>scaleX)?scaleX:scaleY);
  return scaleMin;
