show maximize button in InfoWindow
1122
06-05-2020 09:56 AM
ShaikhRizuan
 I want to add maximize button in infowindow, where on maximize the content also get larger like charts, diagrams etc. Please find below image for example.
when i maximize the size of the pie chart shall also increase.
Regards
KellyHutchins
Esri Notable Contributor
Which version of the JSAPI are you using? The image looks like the InfoWindow which was used as the default popup window prior to version 3.4 of the JSAPI.  If you are using a version later than 3.4 the Popup should be the default and it contains an expand button by default. Here is a sample showing the popup in action:
Popup | ArcGIS API for JavaScript 3.32
