Show/ Hide div on layer visibility
3600
05-14-2015 11:57 AM
CraigLinn
I am trying to get a div container to show when a specific layer is turned on and turn off a div once a new layer is selected.
Please see attached I am open to suggestions. Thanks.
KellyHutchins
Esri Notable Contributor
Craig Linn​ you can use esri/domUtils hide and show methods to quickly hide and show a dom node.  Here's a link to slightly modified version of your code that shows/hides the layer info depending on the toggled check-box.
http://output.jsbin.com/caxukayoho/1/
KellyHutchins
