Sharing common function between web maps.
845
04-03-2012 01:00 AM
CliveSwan
We have 3 map services that share common functions e.g. function init(); FinaliseMap = function()....etc.
The aim is to put the common code into a single file and call the functions as required.
I have tried moving the code to a common file then calling the function from Map A for example.
Get an error calling them??
For example.
I put  function COL.init() in col_common_SHARED.js
Then tried to call function COL.init() in Map Service A (mapA.js).
mapA.js
var function init() = COL.init;
Any suggestions what is wrong AND what I should be doing??
Appreciate any assistance.
derekswingley1
mapA.js
That last line doesn't make sense. If you want to create a variable that points to the COL.init function, you would do this:
var init = COL.init;
Referring to a function by name gets you a reference to it. Adding parentheses immediately after a function name invokes the function.
