Share widget in JavaScript 3.x web app
2505
04-09-2017 02:17 PM
AndreiLuca
Is it possible to integrate a Share widget in a JavaScript 3.20 web app?
There is no such reference or sample code in the ArcGIS API for JavaScript website.
I found a web app that uses this Share widget but not sure where to go from here in order to integrate it in a web app.
Thank you,
Andrei
RobertScheitlin__GISP
Andrei,
   You would need to go get the source code from the Public Information template and strip out the share widget portion. There is not going to be a sample or tutorial for this.
GitHub - Esri/public-information-map-template-js: An ArcGIS Online mapping template to showcase soci...
AndreiLuca
Thank you Robert, the web app source code is a good start.
ESRI not having a sample or tutorial for a widget sharing ESRI products might sound a little strange
MathewSuran
Have you had any success with this AndreiLuca2‌?
AndreiLuca
Hi Mathew Suran
No, just learning to code and this is above my skills for now.
