setTitle not working in infoTemplate
1769
04-25-2013 05:46 AM
KenBuja
MVP Esteemed Contributor
In my app using the 3.4 API, I'm attempting to set the title on an infoTemplate. I've tried
var infoTemplate = new esri.InfoTemplate("Title", contentString);
and
var infoTemplate = new esri.InfoTemplate();
var titleText = "<div>" + "Title" + "</div>"
infoTemplate.setTitle(titleText); //also tried infoTemplate.setTitle("Title");
infoTemplate.setContent(contentString);
but neither of those set the title. The contentString shows up properly, though.
ReneeMaxwell
I've have encountered this bug in 3.3 as well. I discovered that you can workaround it by setting the title AFTER you call setFeatures. Otherwise, any other configuration you employ to set the title will show up blank.
My fix:
var selFeature = results[0].feature;
map.graphics.add(selFeature);
var selLayer = results[0].layerName;
selFeature.setInfoTemplate(template);
map.infoWindow.setFeatures([selFeature]);
//** IMPORTANT! **/
// YOU MUST SET THE TITLE **AFTER** CALLING SETFEATURES
map.infoWindow.setTitle(selLayer);
map.infoWindow.show(evt.mapPoint);
JohnGravois
how is your app different than this sample?
KenBuja
Here's a working example that illustrates the issue.
ReneeMaxwell
My fix:
//** IMPORTANT! **/
