Setting Attributes Dynamically for graphics used in Service Area
1022
03-27-2010 07:53 AM
AdamPfister
Is there a way to dynamically set the attributes used in the features for Service Areas?  I've used the Service Area example from the javascript samples to try and modify.  See below.
Adam
 function mapClickHandler(evt){
      map.graphics.clear(); //clear existing graphics
      //define the symbology used to display the results and input point
      var pointSymbol =  new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_DIAMOND, 20,
            new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
            new dojo.Color([88,116,152]), 2),
            new dojo.Color([88,116,152,0.45]));
      var inPoint = new esri.geometry.Point(evt.mapPoint.x,evt.mapPoint.y,map.spatialReference);
      //this doesn't work
      var location = new esri.Graphic(inPoint, pointSymbol, {
     "FreightCost": 3.50
    }, null);
      map.graphics.add(location);
      var features = [];
      features.push(location);
      var facilities = new esri.tasks.FeatureSet();
      facilities.features = features;
      params.facilities = facilities;
      //solve ...
KellyHutchins
Esri Notable Contributor
Hi Adam,
I think you've already recieved an answer to this question, but I thought I'd post the details here in case others run into this issue. You need to modify the name of the attribute to Attr_<Your Field Name>, which in your case would be "Attr_FreightCost".
Take a look at the 'Facility properties' section of the following help topic for details on the attribute input fields.
http://help.esri.com/en/arcgisdesktop/10.0/help/index.html#/Service_area_analysis/004700000048000000...
You will also need to make sure that the cadidate field names for the Attr_FreightCost attribute contains the Attr_FreightCost value.
AdamPfister
Kelly,
Yes it was making sure the "Candidate Field" value was filled in.  Thanks for checking.
Adam
