Set points, zoom, not working correctly in IE but fine in Chrome and Mozilla.
1945
09-04-2014 09:04 AM
GloriaForthun
I am using 3.9 and in my application I suddenly couldn't zoom-in to the exact spot I wanted to start at.  Then I tried the route stop and that did not go where I tried to put it.  Then I did the drive time and put down the point and it didn't go where I put it.  All the other layers I have added, the find location, popups, etc... all work.  It "appears" that the points are moving to the NW from where I want them.  I am using 4326 and dec. deg.  This has been working fine all along.  It is also working just fine in Chrome and Mozilla.  I have no idea at all why it is doing this in IE.  I have IE 11.  Still very new to this but this is really confusing.  Any help, advice?  Thank you in advance.
KenBuja
This can sometimes be fixed by resizing the map once it's loaded.
  1. map.on("load", function () {
  2.     registry.byId("divMap").on("resize", function () {
  3.         clearTimeout(resizeTimer);
  4.         resizeTimer = setTimeout(function () {
  5.             map.resize();
  6.             map.reposition();
  7.         }, 500);
  8.     });
  9. })
Also, please consider moving this thread in the the JavaScript space
