Set correct scale when zooming to a graphic that is on the graphics layer
2121
11-22-2017 11:00 AM
EvonFranklin
When I add a graphic to the layer and use the zoomTo feature the scope seems to cut off some of the feature within the "MAP" DIV element. Its currently set to 70% of the screen height via CSS and it is kind of puzzling whether this is natural behaviour or its my code I used for styling the page. Can anyone advise me as to if this is natural ?
RobertScheitlin__GISP
Evon,
   Are you talking about 3.x or 4.x? What type of layer are you adding a graphic to?
EvonFranklin
In 4.5 and MapImageLayer
Evon,
  It is likely your code. Can you share a sample that demonstrates this behavior?
HezronPhilip
Sometimes based on the aspect ratio of your monitor the zoom extent might sometimes cut off features (I say this because I've noticed this happening in my widescreen display, while the features load right in a different display). I suggest you use graphicUtils to get the extent of your graphic/graphics and then set that extent to the map. (using the expand property might ensure that all the features are visible on your map.)
//sample
var Extent = graphicsUtils.graphicsExtent([graphic1, graphic2]);
map.setExtent(Extent .expand(3));
