Seperate JS files
6055
12
01-31-2018 06:43 AM
jaykapalczynski
Honored Contributor
I have an app that is starting to get a rather large amount of JS.
I was wondering if I could start to separate certain bits of code in a separate JS file and then just reference them.
If I reference it in HTML as I do the main JS file I get errors saying the map is not defined.
<script src="js/index.js"></script>
<script src="js/elevationprofile.js"></script>
Is there a way to reference all the split out JS files in the main JS file?
KenBuja
MVP Esteemed Contributor
And you're calling dojo/_base/array twice in your code
jaykapalczynski
Honored Contributor
I removed
"dojo/_base/array"   and     array,
I kept
"dojo/_base/array"   and    arrayUtils,
Still same error
EvelynHernandez
I asked this before and it might be useful for u.
https://community.esri.com/message/518589
Right now im using a module bundler to help me on that...
