Send Geometry JSON to aspx Handler using JQuery Ajax Submit
1209
03-18-2012 10:30 PM
SureshRajamani
I am trying to send Javascript api Geometry JSON to Asp.net Handler using Jquery Ajax Submit.But i am getting javascript error while posting GEOMETRY JSON.
Here is my code i am trying.
    var jsondata = dojo.toJson(geometry.toJson());
        $('#ajax-button').click(function () {
            $('#frmUpload').ajaxSubmit({
                data: jsondata,
                contentType: "application/json; charset=utf-8",
                dataType: 'json',
                success: function (r) {
                    $('#ajax-results').html(r);
                    $('input:file').MultiFile('reset');
If i pass the geometry like below it works fine.
                data: ' {"x":-10753913.140888039,"y":4632637.5074609965,"spatialReference":{"wkid":102100}}',
                dataType: 'json',
Please help me how to send the Geometry JSON to server like this
andrewj_ca
Maybe this will help, in the first code example you are passing a json object where as in the second example you are passing text.  And yes, they are different.  Try passing the json as string and then use the "JavaScriptSerializer()" to serialize it in asp.
