Selection graphic disappearing with tabbed browsing
2279
7
08-01-2011 12:15 PM
PaigeBaldassaro
I have a map with selection graphics added to them via Javascript. when the user clicks on the submit button, a new window is added based on the selection. If the user then tabs back to the original map, the selection graphics disappear. I don't understand why. Any ideas?
Paige
derekswingley1
That does sound strange...can you post your code to reproduce this? Maybe on jsfiddle?
PaigeBaldassaro
Ok, I've never used JSFiddle before. But it looks awesome. I may have to use it from now on! I think this is the link to the JS code. http://jsfiddle.net/Soutti/PZt2C/
Also, to see it in action, go here.  www.cmiweb.org/fia/userlogin.aspx. Use [email protected] Guest123 as the login credentials.
Paige
derekswingley1
I'm not an ASP.NET expert but I do know that when you click your submit button it's doing a POST which which reloads the page. This is why your selection is being cleared.
PaigeBaldassaro
Ok, I thought that by controlling the on click event via javascript, it wouldn't actually post the page. My bad. thanks.
derekswingley1
You probably can handle it with JavaScript, try this:
//Handles the click event of the submit button.
function openReport(evt) {
    dojo.stopEvent(evt);
    try {
        var URL = "Report.aspx?" + dojo.byId("SearchParameters").value;
        window.open(URL);
    catch (e) {
        errorHandler(e);
PaigeBaldassaro
Oh, yes, prefect! Thank you!
derekswingley1
Glad I could help!
