Select With Feature Layer Sample -  The points do not appear
1278
08-29-2013 07:48 AM
ionarawilson1
This sample is supposed to select points based on a buffer created by a mouse click. The buffer appears but I can't see the points. I am using Aptana and the file is in the local server. Does anybody know why this does not work? Thanks
https://developers.arcgis.com/en/javascript/jssamples/query_buffer.html
PLadd
I had this problem yesterday and, while I still haven't gotten it to work, you might want to take a look at the proxyURL.  I think that's the issue for me.
PLadd
ionarawilson1
Yes, you are correct Patrick. I did not even know how to create a proxy page, but everything now is working beautifully.Thanks!!!
