Select Features by Drawing a Polygon
3021
07-29-2015 06:51 AM
ShaningYu
Honored Contributor
I need a component to select features by drawing a polygon.  Do you know where this piece of code can be found?  Thanks.
TimWitt2
Instead of buffering a point just use the geometry of a drawing.
Select with Feature Layer | ArcGIS API for JavaScript
RobertScheitlin__GISP
Shaning,
  You will use the Draw Toolbar to draw your polygon geometry.
Draw | API Reference | ArcGIS API for JavaScript
Then you will use the geometry to execute a QueryTask or a selectFeatures method on a FeatureLayer.
TimWitt2
ShaningYu
Honored Contributor
Thanks to both Rob and Tim.  Both answers are correct.  Sorry for the restriction to credit for 2.
TimWitt2
You can always mark Roberts answer as helpful.
