Select features by drawing a point, rectangle, circle, line on the map
998
08-23-2013 11:07 AM
JoseSanchez
Hi all,
I want to add several buttons to select features by clicking a point, drawing a rectangle,  a circle, a line, or a polygon.
http://resources.esri.com/help/9.3/arcgisserver/apis/javascript/arcgis/demos/toolbars/toolbar_naviga...
Any code that might help
Thanks
KenBuja
MVP Esteemed Contributor
Is there a reason you're using the old version of the API (1.6 instead of 3.6)? Take a look at this sample that has a button to draw a rectangle to select features.
