Just going to list the issue in points to be clear:
We have ArcGIS Enterprise hosted in Azure with Azure Active Directory configured as the Identity Provider.
We also have an ArcGIS JavaScript API application hosted in Azure.
The JS application authenticates users with Azure AD at the start and then consumes different map services from ArcGIS Enterprise.
We would like to use secure (not shared) services in the application, but not require the user to login again into the application (SSO). Is there a way to use the already logged-in user details to consume secured map services? Perhaps with tokens from Azure?
Many thanks for any help
