Search widget locator filter
2718
09-11-2018 01:04 PM
by Anonymous User
Not applicable
Hi all,
I am using the ArcGIS Javascript 4.x and try to apply the filter in the documentation but I am not getting it to work. I want the suggested results to be only "California".
Code is here.
//Search widget here
            var searchWidget = new Search({
                view: view,
                popupEnabled: false,
                popupOpen: false,
                resultGraphicEnabled: false,
                includeDefaultSources: false,
                sources: // Default sources[] when sources is not specified
                        locator: new Locator({ url: "//geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer" }),
                        singleLineFieldName: "SingleLine",
                        outFields: ["Addr_type"],
                        name: "ArcGIS World Geocoding Service",
                        placeholder: "Enter an address",
                        resultSymbol: {
                            type: "picture-marker",  // autocasts as new PictureMarkerSymbol()
                            url: this.basePath + "/images/search/search-symbol-32.png",
                            width: 24,
                            height: 24,
                            xoffset: 0,
                            yoffset: 0
                        filter: "State =" + "'" + "California" + "'",
            }, "search");
Any idea?
RobertScheitlin__GISP
Alex,
   The filter property is expecting an object with a property of where.
                view: view,
                popupOpen: false,
                        resultSymbol: {
                            width: 24,
                            height: 24,
                            xoffset: 0,
                            yoffset: 0
                        filter: {where: "State = 'California'"},
            }, "search");
Alex,
                view: view,
                popupOpen: false,
                        resultSymbol: {
                            width: 24,
                            height: 24,
                            xoffset: 0,
                            yoffset: 0
            }, "search");
by Anonymous User
Not applicable
I am not not too sure what field to query to get only california (World geocoder from ESRI)  related suggested results so I went ahead and used a geometry retrieved from a MapImageservice and input it in the search widget and it does not seem to  return only california addresses. Am I missing something here?
 var query = new Query();
            query.where = "NAME = 'California'";
            query.returnGeometry = true;
            var geomcalifornia;
            queryTask.execute(query).then(function (results) {
                console.log(results.features[0].geometry);
                geomcalifornia = results.features[0].geometry;
                view: view,
                popupOpenOnSelect: false,
                        resultSymbol: {
                            width: 24,
                            height: 24,
                            xoffset: 0,
                            yoffset: 0
                        filter: { geomcalifornia }
            }, "search");‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Alex,
   Again the filter is expecting an object with certain properties.
filter: { geometry: geomcalifornia }
by Anonymous User
Not applicable
That did the trick. Thank you Robert!
