Search popup only shows three fields
3390
01-19-2016 11:49 AM
TylerDunn2
Not sure if this is a default or not, but when I get my search results, only three fields show up. Regardless of how many I have set in my index.
Am I missing something? below is the code for the search:
    sources.push({
      featureLayer: new FeatureLayer("https://gis.cityofthornton.net/arcgis/rest/services/External_Webmaps/MasterAddress/MapServer/0 "),
      searchFields: ["ADDRESS"],
      displayField: "ADDRESS",
      suggestionTemplate: "${ADDRESS}",
      exactMatch: false,
      outFields: ["PT_TYPE", "ADDRESS", "CITY", "STATE", "ZIPCODE", "BUS_NAME", "BUS_TYPE", "LANDUSE", "ZONING", "WARD", "SUBDIVISIO", "DEV_NAME"],
      infoTemplate: new InfoTemplate("Address: ${ADDRESS}", "Address Type: ${PT_TYPE}</br>Address: ${ADDRESS}</br>City: ${CITY}", "State: ${STATE}</br>Zipcode: ${ZIPCODE}","Business Name: ${BUS_NAME}</br>Business Type: ${BUS_TYPE}</br>Landuse: ${LANDUSE}", "Zoning: ${ZONING}</br>Ward: ${WARD}", "Subdivision Name: ${SUBDIVISIO}</br>Development Name: ${DEV_NAME}"),
      placeholder: "Search Addresses",
      maxResults: 6,
      maxSuggestions: 6,
      enableSuggestions: true,
      minCharacters: 0
    s.set("sources", sources);
    s.startup();
Tags (1)
GirishYadav
Tyler,
The infoTemplate that you are creating does not have correct parameters. It takes only two parameters (title, content). There are extra "," inside contents:
Use it like this:
new InfoTemplate("Search Results", "Address: ${ADDRESS}</br>Address Type: ${PT_TYPE}</br>Address: ${ADDRESS}</br>City: ${CITY}</br>State: ${STATE}</br>Zipcode: ${ZIPCODE}</br>Business Name: ${BUS_NAME}</br>Business Type: ${BUS_TYPE}</br>Landuse: ${LANDUSE}</br>Zoning: ${ZONING}</br>Ward: ${WARD}</br>Subdivision Name: ${SUBDIVISIO}</br>Development Name: ${DEV_NAME}"),
-Girish
TiffanySelvidge1
Is it always the same 3 fields?
TylerDunn2
Yeah it's always those first three. Here's a screen shot:
TiffanySelvidge1
What happens if you separate ${CITY} and State with a </br>?
TylerDunn2
Even with it fixed for correct breaks, it doesn't work: Thanks for trying to problem solve with me
    sources.push({
      featureLayer: new FeatureLayer("https://gis.cityofthornton.net/arcgis/rest/services/External_Webmaps/MasterAddress/MapServer/0"),
      exactMatch: false,
      infoTemplate: new InfoTemplate("<b>Address: ${ADDRESS}</b>", "<b>Address Type: ${PT_TYPE}</br>","<b>Address: ${ADDRESS}</br>","<b>City: ${CITY}</b>", "<b>State: ${STATE}</br>","<b>Zipcode: ${ZIPCODE}</b>","<b>Business Name: ${BUS_NAME}</br>","<b>Business Type: ${BUS_TYPE}</br>","<b>Landuse: ${LANDUSE}</b>", "<b>Zoning: ${ZONING}</br>","<b>Ward: ${WARD}</b>", "<b>Subdivision Name: ${SUBDIVISIO}</br>","<b>Development Name: ${DEV_NAME}</b>"),
      placeholder: "Search Owners",
      maxResults: 6,
      maxSuggestions: 6,
      minCharacters: 0
    s.startup();
GirishYadav
Tyler,
Use it like this:
-Girish
