Search and Default Editor
8673
22
12-04-2015 08:36 AM
RickeyFight
I am getting a weird result when I search for a location.
I have the Editor widget  and Search basic combined.
When I search for a location, I can zoom to it. Then when I click on any other point to edit it, I get this result:
Has anyone dealt with this?
i think I am looking for a way to clear search when I click anywhere not the search point.
Even when I clear the search bar I still cannot click on a point to edit:
RobertScheitlin__GISP
Can you show me your code that calls initEditing initially?
RickeyFight
Robert,
     map.on("layers-add-result", initEditing);
            function initEditing(event) {
                var featureLayerInfos = arrayUtils.map(event.layers, function (layer) {
                    return {
                        "featureLayer": layer.layer,
                        "isEditable": true,
                        'showAttachments': true,
                        "showDeleteButton": false,
                        "fieldInfos": [{
                            'fieldName': 'Caller_Name',
                            'isEditable': false,
                            'tooltip': 'Caller Name',
                            'label': 'Caller Name:'
                            'fieldName': 'Priority',
                            'isEditable': true,
                            'tooltip': 'Priority',
                            'label': 'Priority:'
                            'fieldName': 'Location',
                            'label': 'Location:'
                            'fieldName': 'Phone',
                            'label': 'Phone:'
                            'fieldName': 'Notes',
                            'isEditable': true,
                            'label': 'Notes:'
                            'fieldName': 'CallType',
                            'isEditable': true,
                            'label': 'CallType:'
                var settings = {
                    map: map,
                    layerInfos: featureLayerInfos
                var params = {
                    settings: settings
              var editorWidget = new Editor(params, 'editorDiv');
                editorWidget.startup();
                //snapping defaults to Cmd key in Mac & Ctrl in PC.
                //specify "snapKey" option only if you want a different key combination for snapping
                map.enableSnapping();
Rickey,
  Here is my recommended code changes:
                window.featureLayerInfos = arrayUtils.map(event.layers, function (layer) {
                    return {
                        "isEditable": true,
                        "fieldInfos": [{
                            'isEditable': true,
                            'label': 'Phone:'
                            'isEditable': true,
                            'label': 'Notes:'
                            'isEditable': true,
                var settings = {
                    map: map,
                var params = {
                    settings: settings
                window.editor = new Editor(params, 'editorDiv');
                window.editor.startup();
            search.on("select-result", lang.hitch(this, function () {
                //if edit tool is enabled we'll have to delete/create
                //so info window behaves correctly.
                on.once(this.map.infoWindow, "hide", lang.hitch(this, function () {
                    search.clearGraphics();
                    console.log("Cleared Search Graphics");
                    _destroyEditor();
                    console.log("Test");
                    reActivateEditor();
            function _destroyEditor() {
                if (this.editor) {
                    this.editor.destroy();
                    console.log("Destroyed editor");
                    this.editor = null;
            function reActivateEditor() {
                var settings = {
                    map: map,
                    layerInfos: window.featureLayerInfos
                var params = {
                    settings: settings
RickeyFight
Robert,
Thank you for your help so far! I have been able to get to what you posted (mostly) by myself. There are two errors that I cannot get by.
The first error occurs when I use the code you provide:
Uncaught TypeError: a.featureLayer.getEditCapabilities is not a function
The second, using the code I came up with to try to get around the layers issue:
Editor: please provide 'layerInfos' parameter in the constructor
esri.AttributeInspector: please provide correct parameter in the constructor
Uncaught TypeError: Cannot read property 'loaded' of undefined
I think this happens because I am trying to move the layerInfos outside of the function. If I keep layerInfos inside the function, I get the error:
Uncaught TypeError: Cannot read property 'layers' of undefined
Which I stated above
Rickey,
   I am going to need to see all your code to provide any further assistance.
RickeyFight
Robert,
Here is all the code:
Edit fiddle - JSFiddle
Thank you for taking time to look at this!
Rickey,
  You were just not keep your var names straight. You had window.editor in one function and window.editorWidget in another (and some other small tweaks).
RickeyFight
Robert,
When I try it in jsfiddle, it works.
When I copy the script to my html and save to server, I get the same error as before. The popup will not display any data.
Rickey,
  This is what I have working fine on my dev machine:
<!DOCTYPE html>
<html>
<head>
    <title>Emergency Loc</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.15/dojox/layout/resources/ExpandoPane.css">
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
    body {
      background-color: #fff;
      overflow: hidden;
      font-family: Helvetica, san-serif;
    #templatePickerPane {
      width: 225px;
      overflow: hidden;
    #Editor {
      heigh: 30%;
    #panelHeader {
      background-color: #92A661;
      border-bottom: solid 1px #92A860;
      color: #FFF;
      font-size: 18px;
      height: 24px;
      line-height: 22px;
      margin: 0;
      overflow: hidden;
      padding: 10px 10px 10px 10px;
    #map {
      margin-right: 5px;
      padding: 0;
    .esriEditor .templatePicker {
      padding-bottom: 5px;
      padding-top: 5px;
      height: 500px;
      border-radius: 0px 0px 4px 4px;
      border: solid 1px #92A661;
    .dj_ie .infowindow .window .top .right .user .content,
    .dj_ie .simpleInfoWindow .content {
      position: relative;
    .dgrid {
      border: none;
      height: 100%;
    .dgrid-column-0 {
      width: 35px;
    .dgrid-row-odd {
      background: #FFFDF3;
    td div img:hover {
      cursor: pointer;
    #HomeButton {
      position: absolute;
      top: 95px;
      left: 20px;
      z-index: 50;
    #LocateButton {
      position: absolute;
      top: 130px;
      left: 20px;
      z-index: 50;
    #search {
      display: block;
      position: absolute;
      z-index: 2;
      top: 20px;
      left: 74px;
    th.dgrid-cell.dgrid-cell-padding.dgrid-column-2.field-Priority.dgrid-sortable {
      width: 20%;
    td.dgrid-cell.dgrid-cell-padding.dgrid-column-2.field-Priority {
      width: 20%;
    #layerListPane {
      width: 25%;
    .esriLayer {
    .esriLayerList .esriList {
      border-top: none;
    .esriLayerList .esriTitle {
      border-bottom: none;
    .esriLayerList .esriList ul {
    /*css rules for the expand div*/
    .esriLayerExpand {
      width: 16px;
      height: 16px;
      float: left;
      margin: 12px 0;
    .esriLayerExpand.expand {
      background-image: url(images/v_right.png);
      background-repeat: no-repeat;
      background-position: center;
      cursor: pointer;
    .esriLayerExpand.collapse {
      background-image: url(images/v.png);
      cursor: pointer;
    /*narrow the margin of the checkbox for aesthetics*/
    .esriLayerList .esriCheckbox {
      margin: 12px 5px 12px 5px;
  </style>
  <script src="http://js.arcgis.com/3.15"></script>
  <script>
    var map, grid;
    require([
      "esri/config",
      "esri/map",
      "esri/SnappingManager",
      "esri/dijit/editing/Editor",
      "esri/layers/FeatureLayer",
      "esri/tasks/GeometryService",
      "esri/toolbars/draw",
      "dojo/keys",
      "dojo/parser", "esri/layers/ArcGISDynamicMapServiceLayer", "dojo/_base/declare", "dgrid/OnDemandGrid",
      "dgrid/Selection", "esri/symbols/SimpleFillSymbol", "esri/Color", "dijit/form/Button",
      "esri/symbols/SimpleMarkerSymbol", "dojo/_base/array", "dojo/dom-class",
      "dojo/i18n!esri/nls/jsapi",
      "esri/tasks/query",
      "dojo/store/Memory", "esri/geometry/Extent", "esri/layers/CodedValueDomain", "esri/layers/Domain",
      "esri/dijit/HomeButton", "esri/dijit/LocateButton",
      "esri/dijit/Search", "esri/dijit/Scalebar", "esri/dijit/LayerList", "dojo/dom-construct", "dojo/dom-style",
      "dojo/dom", "dojo/_base/lang", "dojo/on",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojox/layout/ExpandoPane", "dijit/layout/AccordionContainer",
      "dojo/domReady!"
    ], function (
      esriConfig, Map, SnappingManager, Editor, FeatureLayer, GeometryService,
      Draw, keys, parser, ArcGISDynamicMapServiceLayer, declare, Grid, Selection, SimpleFillSymbol, Color, Button, SimpleMarkerSymbol,
      arrayUtils, domClass, i18n, Query, Memory, Extent, CodedValueDomain,
      Domain, HomeButton, LocateButton, Search, Scalebar, LayerList, domConstruct, domStyle, dom, lang, on
      parser.parse();
      //snapping is enabled for this sample - change the tooltip to reflect this
      i18n.toolbars.draw.start += "<br/>Press <b>CTRL</b> to enable snapping";
      i18n.toolbars.draw.addPoint += "<br/>Press <b>CTRL</b> to enable snapping";
      //This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to
      //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
      //for details on setting up a proxy page.
      esriConfig.defaults.io.proxyUrl = "/proxy/";
      //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications
      esriConfig.defaults.geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
      //var StatesGrid = declare([Grid, Selection]);
      /*____________________________________________Dgrid________________________________________________________________*/
      var columns = [
          label: "", //wasn't able to inject an HTML <div> with image here
          field: "OBJECTID",
          formatter: makeZoomButton
          label: "Location",
          field: "Location"
          label: "Priority",
          field: "Priority"
          label: "Last Contact",
          field: "last_edited_date",
          formatter: formatlast_edited_date
      grid = new StatesGrid({
        bufferRows: Infinity,
        columns: columns
      }, "grid");
      /*____________________________________________Map________________________________________________________________*/
      map = new Map("map", {
        basemap: "topo",
        center: [-122.710375, 42.197994],
        zoom: 16
      /*____________________________________________Home________________________________________________________________*/
      var home = new HomeButton({
        map: map
      }, "HomeButton");
      home.startup();
      /*____________________________________________Locate________________________________________________________________*/
      geoLocate = new LocateButton({
        map: map,
        setScale: false,
        useTracking: true,
        timeout: 15000,
        enableHighAccuracy: true
      }, "LocateButton");
      geoLocate.startup();
      /*____________________________________________Search________________________________________________________________*/
      var search = new Search({
        map: map
      }, "search");
      search.startup();
      /*____________________________________________Edit________________________________________________________________*/
          return {
            "isEditable": true,
            "fieldInfos": [{
              'isEditable': true,
              'label': 'Phone:'
              'isEditable': true,
              'label': 'Notes:'
              'isEditable': true,
        var settings = {
          map: map,
        var params = {
          settings: settings
        editor.startup();
        console.log(search.value);
          _destroyEditor();
          console.log("Starting Editing Again");
          reActivateEditor();
          console.log("Complete");
        if (editor) {
          editor.destroy();
          editor = null;
        var settings = {
          map: map,
        var params = {
          settings: settings
        editor.startup();
      /*____________________________________________Scalebar________________________________________________________________*/
      var scalebar = new Scalebar({
        map: map,
        // "dual" displays both miles and kilmometers
        // "english" is the default, which displays miles
        // use "metric" for kilometers
        scalebarUnit: "english"
      /*____________________________________________Script________________________________________________________________*/
      domClass.add(map.infoWindow.domNode, "light");
      var atlasLayer = new ArcGISDynamicMapServiceLayer("http://gis.ashland.or.us/arcgis/rest/services/pictometry3inch_jason/MapServer", {
        "id": "atlasLayer",
        "showAttribution": false
      var recreationLayer = new ArcGISDynamicMapServiceLayer("http://gis.ashland.or.us/arcgis/rest/services/sandbox/EmerLoc/MapServer", {
        "id": "recreationLayer",
        "showAttribution": true,
        "refreshInterval": 0.038
      var waterNetLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Water_Network/MapServer", {
        "id": "waterNetworkLayer",
      map.addLayers([atlasLayer, recreationLayer, waterNetLayer]);
      var llWidget = new LayerList({
        map: map,
        layers: [{
            layer: atlasLayer,
            subLayers: false
            layer: recreationLayer,
            id: "Emergency Locations",
            subLayers: true
            layer: waterNetLayer,
            id: "Water Network layers",
            subLayers: true
        showOpacitySlider: true,
        showLegend: true
      }, "layerList");
      llWidget.startup();
      /*When the LayerList is loaded enhance it to add collapse capabilities*/
      llWidget.on('load', function () {
        enhanceLayerList();
      /*Work with all the layers*/
      function enhanceLayer(layerNode) {
        layerExpand = domConstruct.create('div');
        domClass.add(layerExpand, 'esriLayerExpand collapse');
        domConstruct.place(layerExpand, layerNode, 'first');
        on(layerExpand, 'click', function (evt) {
          var LayerNodes = query('.esriLayer');
          var SubList = query('.esriSubList', evt.target.parentNode);
          if (domClass.contains(evt.target, 'collapse')) {
            domClass.replace(evt.target, 'expand', 'collapse');
            domStyle.set(SubList[0], 'display', 'none');
          } else {
            domClass.replace(evt.target, 'collapse', 'expand');
            domStyle.set(SubList[0], 'display', '');
        var subListNodes = query('.esriSubListLayer', layerNode);
        if (subListNodes.length > 0) {
          array.map(subListNodes, function (subListNode) {
            enhanceSubList(subListNode);
      /*Now work with all the sublayers*/
      function enhanceSubList(subLayerNode) {
        var subLayerExpand;
        var subListNodes = query('.esriSubListLayer', subLayerNode);
          subLayerExpand = domConstruct.create('div');
          domClass.add(subLayerExpand, 'esriLayerExpand collapse');
          domConstruct.place(subLayerExpand, subLayerNode, 'first');
          on(subLayerExpand, 'click', function (evt) {
            var cState = '';
            var subListLayerNodes = query('.esriSubListLayer', evt.target.parentNode);
              cState = 'collapse';
            } else {
              cState = 'expand';
            array.map(subListLayerNodes, function (subListLayerNode) {
              if (cState === 'collapse') {
                domStyle.set(subListLayerNode, 'display', 'none');
              } else {
                domStyle.set(subListLayerNode, 'display', 'block');
        } else {
          domClass.add(subLayerExpand, 'esriLayerExpand');
      /*Begin with the individual layers*/
      function enhanceLayerList() {
        var layerExpand, subLayerExpand;
        var LayerNodes = Query('.esriLayer');
        arrayUtils.map(LayerNodes, function (layerNode) {
          enhanceLayer(layerNode);
      /*____________________________________________AddLayers________________________________________________________________*/
      var operationsPointLayer = new FeatureLayer("http://gis.ashland.or.us/arcgis/rest/services/sandbox/EmerLoc/FeatureServer/0", {
        mode: FeatureLayer.MODE_ONDEMAND,
        outFields: ["*"],
        refreshInterval: 0.038
      map.addLayers([operationsPointLayer]);
      map.infoWindow.resize(400, 300);
      //add the states demographic data
      var statesLayer = new FeatureLayer("http://gis.ashland.or.us/arcgis/rest/services/sandbox/EmerLoc/MapServer/0", {
        mode: FeatureLayer.MODE_SELECTION,
        outFields: ["OBJECTID", "Priority", "Location", "last_edited_date", "CallType"]
      //create Selection Symbol
      var highlightSymbol = new SimpleMarkerSymbol({
        "color": [0, 112, 255, 255],
        "size": 10,
        "angle": 0,
        "xoffset": 0,
        "yoffset": 14,
        "type": "esriSMS",
        "style": "esriSMSDiamond"
      statesLayer.on("load", function (evt) {
        var query = new Query();
        query.where = "1=1";
        statesLayer.refreshInterval = 0.03;
        query.outFields = ["OBJECTID", "Priority", "Location", "last_edited_date", "CallType"];
        query.returnGeometry = true;
        statesLayer.queryFeatures(query, function (featureSet) {
          var items = arrayUtils.map(featureSet.features, function (feature) {
            var fields = statesLayer.fields;
            return feature.attributes;
          //idProperty must be set manually if value is something other than 'id'
          var memStore = new Memory({
            data: items,
            idProperty: "OBJECTID"
          window.grid.set("store", memStore);
          window.grid.set("sort", "last_edited_date", " descending: false");
          grid.on(".field-OBJECTID:click", function (e) {
            //retrieve the ObjectId when someone clicks on the magnifying glass
            if (e.target.alt) {
              zoomRow(e.target.alt);
        }, function (error) {
          console.info(error);
        statesLayer.clearSelection();
      map.addLayer(statesLayer);
      statesLayer.setRefreshInterval(0.083);
      map.on("click", function (evt) {
        grid.clearSelection();
      function makeZoomButton(id) {
        //set the feature 'id' as the alt value for the image so that it can be used to query below
        var zBtn = "<div data-dojo-type='dijit/form/Button'><img src='images/zoom.png' alt='" + id + "'";
        zBtn = zBtn + " width='15' height='15'></div>";
        return zBtn;
      //center at the selected feature on the map from the row in the data grid
      function zoomRow(id) {
        grid.refresh();
        query.objectIds = [id];
        console.info(id);
        statesLayer.selectFeatures(query, FeatureLayer.SELECTION_SUBTRACT, function (features) {
          //re-centre map to zoom to the selected feature
          if (features.length) {
            // re-center the map to the selected feature
            map.centerAt(features[0].geometry, 0.9);
          } else {
            console.log("Feature Layer query returned no features... ", features);
      function formatlast_edited_date(value) {
        var inputDate = new Date(value);
        return dojo.date.locale.format(inputDate, {
          selector: 'date',
          datePattern: 'MM/dd/yyyy HH:mm'
  </script>
</head>
<body class="claro">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width:100%; height:100%;">
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
      <div id="search"></div>
      <div id="HomeButton"></div>
      <div id="LocateButton"></div>
    </div>
    <div data-dojo-type="dojox/layout/ExpandoPane" data-dojo-props="duration:300, title:'Layer List', splitter:true, region:'right', maxWidth:'220px', startExpanded:false, easeIn:'easing.linear', easeOut:'easing.linear'" style="width:22%;">
      <div id="layerListPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
        <div id="layerList"></div>
      </div>
    </div>
    <div data-dojo-type="dojox/layout/ExpandoPane" data-dojo-props="duration:300, title:'Calls', splitter:true, region:'left', maxWidth:'220px', easeIn:'easing.linear', easeOut:'easing.linear'" style="width:22%;">
      <div data-dojo-type="dijit/layout/ContentPane" id="templatePickerPane" data-dojo-props="region:'left', maxWidth:'220px'" style="width:30%;">
        <!--<div id="Editor" >
      <div id="panelHeader" style="height:20%;">
        Default Editor
      </div>-->
        <div id="grid" style="height:75%;"></div>
      </div>
    </div>
  </div>
</body>
</html>
RickeyFight
Robert,
Here is your code on my server.
Emergency Loc
Does it work for you?
Thank you!
