Screen goes blank after page loads
2595
5
09-30-2013 09:45 AM
KennethRichards
Every time I load my web page the everything displays for half a second and then the screen goes blank. It appears that all of my html elements are given a height of 0.
Can anyone see what I am missing?
[HTML]
<!DOCTYPE HTML>
<html>
<head>
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <title>Text Search</title>
    <link rel="stylesheet" href="styles/Base.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dojox/grid/resources/Grid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dojox/grid/resources/tundraGrid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css">
    <script>var dojoConfig = {parseOnLoad:true};</script>
    <script src="http://js.arcgis.com/3.6/"></script>
    <script src="scripts/App2.js"></script>
</head>
<body class="tundra">
<div id="titleBar">
<div id="titleText" class="mapMenus">
    <a href='http://azogcc.az.gov/'>ARIZONA OIL AND GAS <br>CONSERVATION COMMISSION</a>
</div>
<div id="navigationMenu" class="mapMenus">
    <ul>
        <li><a href='http://azogcc.az.gov/'>Home</a></li>
        <li><a href='http://azgs.az.gov/'>AZGS</a></li>
        <li><a href='http://welldata.azogcc.az.gov/index.html'>Map Search</a></li>
        <li><a href='http://welldata.azogcc.az.gov/textsearch.html'>Text Search</a></li>
    </ul>
</div>
    <div id="titleImg" class="mapMenus">
        <a href='http://azgs.az.gov/'><img src="photos/AZ_state_seal2.png" height="49" width="49"></a>
    </div>
</div>
<div id="search_body"
     data-dojo-type="dijit/layout/BorderContainer"
     data-dojo-props="design:'headline', gutters:true"
     style="width: 100%; height: 100%; margin: 0;">
<div id="search_info"
        data-dojo-type="dijit/layout/ContentPane"
    data-dojo-props="region:'top'">
    <div id="info">
    <p>
        <strong> Text Search:</strong> Complete one or multiple fields and press the Submit Search button to search for wells based on their attributes. Selecting LAS data will open the LAS data in a text file. The selected LAS data can be saved and downloaded by using the save page as function.
    </p>
        </div>
    </div>
    <div id="info">
    <p>
    </p>
        </div>
    </div>
<div id="image_box"
    data-dojo-props="region:'right'">
    <img src="photos/Arizona_Meridians_Labled.jpg" height="385" width="350">
        <div id="img_info">
            <p>Map of Arizona State Meridians</p>
        </div>
</div>
<div id="forum"
     data-dojo-props="region:'left'">
<form action="">
    <table>
        <tr>
            <td class="label">
                <label for="apinum">API Number</label>
            </td>
            <td>
                <input type="text" name="apino" id="apinum" size="14" maxlength="14" placeholder="02-005-00000"><br>
            </td>
        </tr>
  <tr>
            <td>
                <input type="button" id="executeApi" value="Search by API"/>
            </td>
        </tr>
  </table>
  </form>
</div>
<div id="outGrid"
    data-dojo-props="region: 'bottom'" style="height: 100%;">
    <table data-dojo-type="dojox.grid.DataGrid" jsid="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'" style="height:100%; width:100%">
        <thead>
        <tr>
            <th field="apino" width="auto">API No</th>
            <th field="otherid" width="auto">State Permit No</th>
            <th field="wellname" width="auto">Operator</th>
            <th field="county" width="auto">County</th>
            <th field="twp" width="auto">Township</th>
            <th field="rge" width="auto">Range</th>
            <th field="section_" width="auto">Section</th>
            <th field="drillertotaldepth" width="auto">Depth (ft)</th>
            <th field="formationtd" width="auto">Formation at Depth</th>
            <th field="folderField" width="auto" >Well Folder</th>
            <th field="logField" width="auto" >Scanned Well Log</th>
            <th field="lasField" width="auto" >LAS Data</th>
        </tr>
        </thead>
    </table>
</div>
</div>
</body>
</html>
[/HTML]
CSS
head{     height: 100%;     width: 100%; } body {     background: -webkit-gradient(linear, left bottom, left top, color-stop(0.46, rgb(250, 243, 232)), color-stop(0.67, rgb(244, 226, 207)), color-stop(0.87, rgb(233, 202, 161))) no-repeat;     background: linear-gradient(bottom, #FAF4E8 46%, #F4E3CF 67%, #E9CAA1 87%);     background: -o-linear-gradient(bottom, #FAF4E8 46%, #F4E3CF 67%, #E9CAA1 87%);     background: -moz-linear-gradient(bottom, #FAF4E8 46%, #F4E3CF 67%, #E9CAA1 87%);     background: -ms-linear-gradient(bottom, #FAF4E8 46%, #F4E3CF 67%, #E9CAA1 87%);     height: 100%;     width: 100%;     margin: 0; } #titleBar{     position:relative;     overflow: hidden; } #titleText{     padding-left: 1px;     text-align: left;     z-index: 5;     position: absolute;     left: 1%;     font-family: "Helvetica Nueue","Trebuchet MS",Arial,"Nimbus Sans L",FreeSans,sans-serif;     font-weight: bold;     font-size: 125%;     overflow: inherit; } #titleImg{     position: absolute;     right: 1%;     top: 5%;     z-index: 5;     padding-right: 1px;     overflow: inherit; } #navigationMenu {     background: -webkit-gradient(linear,left bottom,left top,color-stop(0.08, #B87147),color-stop(0.54, #9B440E) );     background: linear-gradient(bottom, #B87047 8%, #9B440E 54%);     background: -o-linear-gradient(bottom, #B87047 8%, #9B440E 54%);     background: -moz-linear-gradient(bottom, #B87047 8%, #9B440E 54%);     background: -ms-linear-gradient(bottom, #B87047 8%, #9B440E 54%);     border: 1px gray;     padding:1px;     color: #feffff;     text-align: center;     z-index: 5; } #navigationMenu li {     display:inline;     padding: 25px; } .mapMenus a:link{     color: #feffff;     text-decoration: none; } .mapMenus a:visited{     color: #feffff;     text-decoration: none; } .mapMenus a:hover{     color: #feffff;     text-decoration: underline; } .mapMenus a:active{     color: #feffff;     text-decoration: none; } #search_body{     height: 100%; } #search_info {     border-left:1px solid gray;     border-right:1px solid gray;     border-top:1px solid gray;     border-bottom:1px solid gray;     background: #E9CAA1;     margin-left: 2px;     margin-top: 2px;     margin-right: 2px; } #image_box {     border:1px solid gray;     padding-right:10px;     padding-top:10px;     padding-left:10px;     padding-bottom:10px;     margin-top:2px;     margin-right:2px; } #img_info {     border-top:1px solid gray;     padding-bottom:10px;     padding-left:10px;     padding-right:10px;     margin-left:-10px;     margin-right:-10px; } form table {     border:1px solid gray;     width: 382px;     margin-top:2px;     margin-left:2px; } #search_body { border:2px solid gray;     height: 100%; } #outGrid{     height: 22%;     font-size: 75%; }
ZachLiu1
Examine your whole layout.
The BorderContainer takes up the whole screen with
Each ContentPane (Top, Bottom, Left, Right) should all have its own size for the layout to work, you may be missing some.
ZachLiu1
head {
    height: 100%;
    width: 100%;
should be
html {
    height: 100%;
    width: 100%;
KennethRichards
head {
    height: 100%;
    width: 100%;
should be
html {
    height: 100%;
    width: 100%;
I can't believe I didn't see that. Now I just need to get the grid to not fill the whole screen. Any ideas there?
ZachLiu1
We've all missed some super stupid mistakes, 🙂
to follow up, I think you have a inline style for your "outgrid"
is that the issue?
KennethRichards
is that the issue?
I erased that and it didn't seem to change anything. It was a good idea though.
ZachLiu1
