SceneLayer and ScenLayerView query support
5202
11
10-20-2017 09:44 AM
Yunpiao_WhitneyBai
I published a sceneLayer to AGOL through a scene layer package. I'm trying to query the scene layer view / this scene layer using  queryFeature() method. But I found that none of the attributes  support query when I use getFieldUsageInfo(field) to check the field.
Since the this scene layer contains a large dataset, I really want to query the layerView instead of the whole layer using queryTask or linked Featurelayer. Does anyone know how can I fix this issue to make the field support query?
thanks,
Yunpiao_WhitneyBai
Hi Raluca,
Sorry for the late response. Here are some data some data you can use for testing. Case#01955480.ppkx - Google Drive
The building can display correctly but only with the drawing info.
Also, I found that if I publish feature class with z value, the z value actually get stripped off if it is a donuts polygon. We really hope can solve some of the publishing issue with scene layer.
thanks,
RalucaNicola1
ok, thanks for the data, I'll have a look at it by the end of this week and come back with a reply.
