Sample using Power Pages
538
01-07-2026 01:50 PM
JairoPo
Hi, I was wondering if there are any tutorials or samples on how to integrate an ArcGIS map with Power Pages. The basic features would include dropping a pin and showing other pins on the same map.
Tags (1)
VenkataKondepati
Honored Contributor
Hi JairoPo,
There is no out-of-the-box connector. You can embed an ArcGIS Maps SDK for JavaScript application using a Liquid Template or an iFrame within your Power Pages site. For the "dropping a pin" functionality, you can look at the Sketch ViewModel samples to capture coordinates and save them back to your Dataverse or ArcGIS feature service via a web API call.
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
