Sample Identify not working for Numbers
1148
06-28-2010 10:56 AM
JoshuaWallin
I am using the sample Identify Code from the resource center and I modified to use it on my own data.  When I try to get feature information from a field that is a number type, the table throws up an undefined instead of showing the value.  I am assuming it is because the variable is of the wrong type or I have to make a conversion but I cannot spot the problem.  Please Help
The below link brings you to the original code
http://resources.esri.com/help/9.3/arcgisserver/apis/javascript/arcgis/help/jssamples/identify_drill...
derekswingley1
Can you post your code that isn't working?
JoshuaWallin
This is the code directly from the sample.  It works in the sample and when I point it at my map, feature classes, and fields it works for Text classes.  When I point it at a Long or Integer class it comes up with an <undefined> as a result instead of showing the value
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <title>Identify Sample</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/1.6/js/dojo/dijit/themes/tundra/tundra.css">
    <script type="text/javascript">djConfig = { parseOnLoad:true }</script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6"></script>
      dojo.require("esri.map");
      dojo.require("esri.tasks.identify");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("dijit.layout.TabContainer");
      dojo.require("dijit.form.Button");
      var map, identifyTask, identifyParams, symbol;
      var layer2results, layer3results, layer4results;
      function init() {
        map = new esri.Map("mapDiv", { extent: new esri.geometry.Extent(-122.580,45.482,-122.571,45.488, new esri.SpatialReference({wkid:4326})) });
        dojo.connect(map, "onLoad", initFunctionality);
        var imageryPrime = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_Imagery_World_2D/MapServer");
        map.addLayer(imageryPrime);
        var portlandLandBase = new esri.layers.ArcGISTiledMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Portland/Portland_ESRI_LandBase_AGO/MapSe...");
        portlandLandBase.setOpacity(0.65);
        map.addLayer(portlandLandBase);
        dojo.connect(map.infoWindow, "onShow", function() {
          dijit.byId("tabs").resize();
      function initFunctionality(map) {
        dojo.connect(map, "onClick", doIdentify);
        identifyTask = new esri.tasks.IdentifyTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Portland/Portland_ESRI_LandBase_AGO/MapSe...");
        identifyParams = new esri.tasks.IdentifyParameters();
        identifyParams.tolerance = 3;
        identifyParams.returnGeometry = true;
        identifyParams.layerIds = [2,3,4];
        identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
        identifyParams.width  = map.width;
        identifyParams.height = map.height;
        map.infoWindow.resize(415, 200);
        map.infoWindow.setContent(dijit.byId("tabs").domNode);
        map.infoWindow.setTitle("Identify Results");
        symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.5]));
      function doIdentify(evt) {
        map.graphics.clear();
        identifyParams.geometry = evt.mapPoint;
        identifyParams.mapExtent = map.extent;
        identifyTask.execute(identifyParams, function(idResults) { addToMap(idResults, evt); });
      function addToMap(idResults, evt) {
        layer2results = {displayFieldName:null,features:[]};
        layer3results = {displayFieldName:null,features:[]};
        layer4results = {displayFieldName:null,features:[]};
        for (var i=0, il=idResults.length; i<il; i++) {
          var idResult = idResults;
          if (idResult.layerId === 2) {
            if (!layer2results.displayFieldName) {layer2results.displayFieldName = idResult.displayFieldName};
            layer2results.features.push(idResult.feature);
          } else if (idResult.layerId === 3) {
            if (!layer3results.displayFieldName) {layer3results.displayFieldName = idResult.displayFieldName};
            layer3results.features.push(idResult.feature);
          } else if (idResult.layerId === 4) {
            if (!layer4results.displayFieldName) {layer4results.displayFieldName = idResult.displayFieldName};
            layer4results.features.push(idResult.feature);
        dijit.byId("layer2Tab").setContent(layerTabContent(layer2results,"layer2results"));
        dijit.byId("layer3Tab").setContent(layerTabContent(layer3results,"layer3results"));
        dijit.byId("layer4Tab").setContent(layerTabContent(layer4results,"layer4results"));
        map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
      function layerTabContent(layerResults, layerName) {
        var content = "";
        switch (layerName) {
          case "layer2results":
            content = "<i>Total features returned: " + layerResults.features.length + "</i>";
            content += "<table border='1'><tr><th>TLID</th><th>Owner</th><th>Value</th></tr>";
            for (var i=0, il=layerResults.features.length; i<il; i++) {
              content+="<tr><td>"+layerResults.features.attributes['TLID']+" <a href='#' onclick='showFeature(" + layerName + ".features[" + i + "]); return false;'>(show)</a></td>";
              content+="<td>"+layerResults.features.attributes['OWNER1']+"</td>";
              content+="<td>"+layerResults.features.attributes['TOTALVAL']+"</td>";
            content+="</tr></table>";
            break;
          case "layer3results":
            content += "<table border='1'><tr><th>Building ID</th><th>Area</th></tr>";
              content+="<tr><td>"+layerResults.features.attributes['OBJECTID_1']+" <a href='#' onclick='showFeature(" + layerName + ".features[" + i + "]); return false;'>(show)</a></td>";
              content+="<td>"+layerResults.features.attributes['Shape_Area']+"</td>";
            break;
          case "layer4results":
            content += "<table border='1'><tr><th>ID</th><th>Zone</th><th>Zone Class</th><th>General Class</th></tr>";
              content+="<tr><td>"+layerResults.features.attributes['OBJECTID']+" <a href='#' onclick='showFeature(" + layerName + ".features[" + i + "]); return false;'>(show)</a></td>";
              content+="<td>"+layerResults.features.attributes['ZONE']+"</td>";
              content+="<td>"+layerResults.features.attributes['ZONE_CLASS']+"</td>";
              content+="<td>"+layerResults.features.attributes['ZONEGEN_CL']+"</td>";
            break;
        return content;
      function showFeature(feature) {
        feature.setSymbol(symbol);
        map.graphics.add(feature);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="tundra">
    Click the map to identify buildings, parcels, and zoning information.
    <div id="mapDiv" style="width:800px; height:600px; border:1px solid #000;"></div>
    <!-- info window tabs -->
    <div id="tabs" dojoType="dijit.layout.TabContainer" style="width:385px;height:150px;">
      <div id="layer2Tab" dojoType="dijit.layout.ContentPane" title="Tax Lots"></div>
      <div id="layer3Tab" dojoType="dijit.layout.ContentPane" title="Buildings"></div>
      <div id="layer4Tab" dojoType="dijit.layout.ContentPane" title="Zoning"></div>
    </div>
  </body>
</html>
JoshuaWallin
content += "<td>" + layerResults.features.attributes['FieldName'] + "</td>";
is what's displaying the value and it seems that for the number classes it is not receiving a value to put in.  Though it works for string fields.  I can't convert it to a string or number because no value comes across from the feature to put in the datagrid
