route simulation with driving directions using javascript
3608
07-07-2015 12:28 AM
jimmiraza
How to simulate route with driving directions. driving direction should be speak turn by turn like real gps navigator application. I have set of driving directions and i want to speak it on each driving direction reached. i am doing like below. here distance is the distance between last gps possition to current gps possition . and dd is the variable for driving direction which will be increase on each driving direction reached.
var tempP;
var xy = DrivingDirectionGeomatry.XY[dd];
if (DrivingDirectionGeomatry != undefined)
var length = dojo.number.format(DrivingDirectionGeomatry.Attributes[dd].length)
var point = new esri.geometry.Point({ "x": xy[0], "y": xy[1], "spatialReference": { " wkid": appLayers.map.spatialReference } });
  tempP
= point;
var d = dojo.number.format(distance);
var remDistance = dojo.number.format(length - d);
if (remDistance < 0) {
return;
if ((remDistance <= 100 && remDistance > 0 || remDistance == length) && DrivingDirectionGeomatry.IsTraval[dd] == false) {
  txtToSpeech
.Speak(DrivingDirectionGeomatry.Attributes[dd].text, TextToSpeech.SpeechRate.VeryLow, TextToSpeech.PitchRate.Normal);
DrivingDirectionGeomatry.IsTraval[dd] = true;
  lastPossition
.lat = null;
  lastPossition
.lon = null;
  currentPossition
.distance = null;
  dd
