Route not displayed after update to chromium 145/146 on Raspberry Pi 4
2501
13
03-26-2026 06:43 AM
Alamos
after updating the raspberry pi chromium to version 146, the route calculated on the map is not visible any more.
I dont see an error in the browser log.
To be sure that the my app is not the cause of the issue, i also tried it on the example page https://developers.arcgis.com/javascript/latest/sample-code/directions-routelayer/
There is no route visible on chromium 145 (and chromium 146), too.
On chromium 142 it has been working without any issues.
WebGL is hardware accelerated according chrome://gpu list, WebGPU is disabled.
The maps are displayed without problems.
Do you have an idea?
Thanks!
Tags (3)
Alamos
Thank you. I'm going to open an issues there, soon.
But we've found out that when we use arcgis sdk in version 4.28 in the geo figures sample page, it is working, with version 4.29 not. Maybe there was a major change on your side?
Thanks in advance.
MaxKirschling
I just wanted to chime in and say I am experiencing the exact same issue with the exact same hardware/software combo. The only thing I have to add is that when I view the route-layer sample page (https://developers.arcgis.com/javascript/latest/sample-code/directions-routelayer/), the full route does not display (same as OP) but when I hover over a specific step of the route it will display that specific route segment.
@Alamos, did you ever post the bug on issues.chromium.org? If so, could you provide the bug ID#? I would like to follow it for any updates from
MaxKirschling
I wanted to share a workaround that I figured out, although it comes with a cost. For reference, this was used on a Raspberry Pi 5 running PiSignage. Based on the solution I discovered, the problem seems to be with OpenGL ES (GLES), as the routing layer was correctly calculating the route but wouldn't actually draw it.
My Workaround
The solution was to force Chromium to utilize swiftshader instead of gles. This change resulted in the routing layer drawing on screen, but at the cost of some performance (as swiftshader is a software based renderer that utilizes the CPU rather than any onboard GPU).
Using a terminal on the Pi device, or via an SSH connection, I created a file:
sudo nano /etc/chromium.d/01-pisignage
and added a single line:
CHROMIUM_FLAGS="--use-angle=swiftshader --enable-unsafe-swiftshader"
Because we are using PiSignage, there were other files on the device that were also injecting (conflicting) flags to the Chromium startup. I also had to edit the files located at:
  • /etc/alternatives/gnome-www-browser
  • /etc/alternatives/x-www-browser
By searching for "--use-angle=", I was able to replace the text
--use-angles=gles
 with
--use-angles=swiftshader --enable-unsafe-swiftshader
After that switch, everything worked, although there is a noticeable drop in response-time. Hopefully this will help someone out there with a similar issue, at least until the devs at Esri and/or Chromium can squash this bug.
Alamos
thanks for the workaround.
Our customer opened an offical bug / ticket on Esri and I think they are going to investigate this issue. They could already reproduce it by theirselves so I am optimistic that we get a solution or fix soon.
