Reverse Directions?
1660
10-25-2013 05:08 AM
StevenGraf1
How would you go about reversing the directions using the closestFacilityTask widget from esri?
https://developers.arcgis.com/en/javascript/jssamples/routetask_closest_facility.html
StevenGraf1
I figured it out.  Undo what what stated earlier and add the following parameter
[HTML] params.travelDirection = 'esriNATravelDirectionFromFacility';[/HTML]
ManishkumarPatel
If you need to reverse the directions just interchange the facilities and incidents
params.incidents = facilities;
params.facilities = incidents;
Have a look at this fiddle: http://jsfiddle.net/Hgv3B/4/
Hope this helps.
Thanks & Regards,
Manish
StevenGraf1
Thanks!  I figured it was something simple like that.
StevenGraf1
I noticed then when you change the params that it doesn't call the right number of resources.  Is there a way to fix this?
StevenGraf1
