Retrieving a WMS service
1840
05-21-2014 08:08 AM
DanielNwankwo
I am asking if there is a way to create a WMSLayer from a WMS url.
I am under the following constraints
A) I cannot use the proxy solution as our production infrastructure does not allow outbound communications
B) The WMS URL is not within our network domain, so I am facing 'same site origin policy' issues
Does anyone know of another way to consume an external WMS service.
Secondly, if I do, somehow, get the XML data from the WMS service, is there a way to create the
WMSLayer object by supplying the raw XML data and no URL.
Most appreciated.
Daniel
RahulMetangale1
Hi Danoski,
As per ArcGIS JS api documentation of WMS layer class:
"The default behavior of a WMSLayer is to execute a WMS GetCapabilities request, which requires using a proxy page. An alternate approach is to pass a resourceInfo object into the constructor which does not require a GetCapabilities request. "
So if you pass resourceInfo it should not use proxy page.
I hope it helps.
Regards,
Rahul
RahulMetangale1
Hi Danoski,
I hope it helps.
Regards,
Rahul
DanielNwankwo
Hello Rahul,
Thnak you for you help. I can now display the WMS map using the resourseInfo. However if I set the baseMap of my map object to 'streets' the WMS map does not show anymore.
Not sure why that would be, I only have one layer
