Retain popup data after it is closed
6472
24
04-01-2020 08:50 PM
rsharma
I want to retain popupdata which i filled in it, when i close the popup coming from marker symbol , and again open it, my popup refreshed.??
RobertScheitlin__GISP
Sure don't call the sketchviewmodel update method immediately like you are.
rsharma
Ok , but why it automatically select polygon for editing when i select marker placed on it, only marker shoul be selected
rsharma
Immediatly means where
Rajni,
  When you add a new graphic to the map you have places in your code you call
sketchViewModel.update(evt.graphic, .....
This is what puts it in edit mode. So where all depends on what action you did prior (i.e. draw a polygon, link from database, etc.)
rsharma
Resolved it i put opposite lat long.
