REST Query input geometry: dissolved polygons
622
02-12-2020 01:27 PM
JamesCrandall
MVP Alum
We are successfully using polygon features as the input Geometry on a point feature service to select those points that intersect.  However, this same exact query fails using the same polygon features that we dissolved on an attribute to generate multi-part polygons.
Is it possible to use the ring feature of a  multi-part polygon as the input geometry for a rest query?
