REST API / createservice / tags
875
12-07-2021 10:34 AM
rbossio
REST API method createservice does not save tags. Is this a known issue or am I missing something? I'm clearly setting it based on documentation but when I look at the service in the portal, tags are empty.
ABishop
MVP Alum
Are you using the createservice to replace a service that has tags?  Or have you assigned them in your method?
Amanda Bishop, GISP
